Local Time 11:30 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Printing unsigned integers
Posted: 08:09am 07 Mar 2021
Hi folks,
I've been having a mental block on this one for 24 hours, even though it feels a bit like a standard interview problem you might ask a graduate programmer.
I want an algorithm to print the unsigned integer corresponding to a negative signed 32 bit integer, e.g. given -254 it will print "4294967042" (a number larger than can be held by a signed 32 bit integer.)
The rub is you only have:
       32 bit integers
       Signed 32-bit arithmetic
       Logical shifts
       Single character printing, i.e. putchar(ch)
Ideally the algorithm would print in an arbitrary base 2 .. 36, but I would settle for base 10 at the moment.
Can anyone help, or point me at a reference?
Edited 2021-03-07 18:11 by thwill
jirsoft
Posted: 04:01pm 07 Mar 2021
Hi Tom,
I will simply start so (for negative number, so bit 31 set)
last = inputValue MOD base
last = (256 + last) MOD base
inputValue = inputValue / base
Now you have already inputValue in smaller range (so it can be used same as positive value), you will convert it to base and on the end output also last.
I think this can work...
Jiri
Posted: 04:05pm 07 Mar 2021
  jirsoft said  Hi Tom,
Thanks Jiri, I've finessed it for the moment by breaking some of the restrictions, but I will definitely look ath this when I get a moment.
Edited 2021-03-08 02:05 by thwill
