Local Time 21:38 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Raspberry Pi 4 with MMBasic with 4K resolution?
bar1010
Posted: 04:36am 04 Mar 2021
Does anyone have a Raspberry Pi 4 running MMBasic with 4K resolution?
From what I understand Raspberry Pi 4 can support 4K resolution and MMBasic
is available for at least one of the Raspberry Pi computers, but am not sure if
MMBasic is available specifically on the Raspberry Pi 4 and if MMBasic
supports the 4K resolution "mode".
Posted: 07:55am 04 Mar 2021
MMbasic on the Raspberry Pi is no longer supported. There are various versions posted on TBS that may or may not work for any particular application but the number of Pi variants and the constantly moving target of the OS with the overhead of Linux makes it impracticable to support.
lew247
Posted: 08:00am 04 Mar 2021
No it won't work on the Pi 4
Pi-cromite manual look up HDMI
but it only works on the Pi 3 and below but only works with early versions of Stretch if you want to use Buster or Pi OS it won't work
