Local Time 11:30 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LINUX: Upgrade from ext2 to ext4....
Posted: 05:35am 01 Mar 2021
Hi all.
Is there any way to convert an ext2 volume to ext4 WITHOUT wiping the drive?
I have four HDD's that were setup originally in NASlite2 that used ext2.
I now use Puppy Linux for pretty much all my SAMBA servers, and choose ext4 by default when setting up a new NAS.
The old ext2 drives from the NASlite2 setup work just fine inside of Puppy Linux, but I would prefer to change the filesystem to ext4 now, as ext2 is getting on a bit, and has those nightmarish fsck checks that take HOURS to complete, whereas ext4 does not.
If this is simply not possible without reformatting and rebuilding, fine.
But I know that Linux has many tricks up its OS sleeve for all sorts of things, and I am kinda hoping that a non-destructive FS upgrade is something you can do.
LeoNicolas
Posted: 05:43am 01 Mar 2021
Yes, there is a way to do it.
Please backup all your data before starting the process.
https://wiki.archlinux.org/index.php/ext4#Migrating_from_ext2/ext3_to_ext4
HellbentHorse
Posted: 05:48am 01 Mar 2021
You can do this, you just can't convert it while the drive is mounted.
This is a pretty good guide.
https://www.howtoforge.com/tutorial/migrate-ext2-ext3-filesystem-to-ext4/
Posted: 07:32am 01 Mar 2021
Lovely, thanks chums - I will read those links.
Posted: 08:16am 01 Mar 2021
  LeoNicolas said  Yes, there is a way to do it.
If you back up all your data, please do the backup on an EXT4 drive.
That solves your problem.
SimpleSafeName
Posted: 12:28pm 01 Mar 2021
Exactly what I was thinking. :)
I still have some drives that pre-date ReiserFS holding all of my important stuff. You know, like my Netscape email from the 90's. On my Iomega Zip drive...
