Local Time 11:37 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 - MATH(MAX(A())
Nimue
Posted: 03:46pm 25 Feb 2021
Using the above I can return the maximum of the array.
Is there a clever way to find the index of said maxium.
Ie:
a(0) = 10
a(1) = 12
a(2) = 9
a(3) = 3
Math(Max(a()) will give me 12.   How can I return index  (1) for that without comparing every value in the array to this max?
edit>>> I could sort the array and return the first element  >> presumably quicker that me coding the comparision.
Off to try.
Got it >>> SORT array() [,indexarray()]    << use the index array.
N
Edited 2021-02-26 02:00 by Nimue
