Local Time 11:37 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 5.07.00b15 OPTION Y_AXIS UP - not working
Nimue
Posted: 01:50pm 25 Feb 2021
Hi
OPTION Y_AXIS UP -- on run, no display  -- but program executes unseen
OPTION Y_ASIS DOWN -- all works fine
Seems that Y_AXIS UP is suppressing screen output until the program terminates.
N
Posted: 02:03pm 25 Feb 2021
More information needed - example program - what mode etc. etc. etc.
Edited 2021-02-26 00:03 by matherp
Nimue
Posted: 02:17pm 25 Feb 2021
  matherp said  More information needed - example program - what mode etc. etc. etc.
Any program - even a simple for / loop with print statement.   Will test modes and report fully.
N
Posted: 02:23pm 25 Feb 2021
The default print position is 0,0 which is off the screen. With option y_axis up you need to position the cursor. Try
PRINT @(0,mm.vres-1)"Hello"
Nimue
Posted: 02:34pm 25 Feb 2021
  matherp said  The default print position is 0,0 which is off the screen. With option y_axis up you need to position the cursor. Try
Works - my error.
That said, something odd with my monitor and modes -- usually Mode 9 -- not the CMM2.
Thanks for the assist.
N
