Local Time 21:55 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with Redimensioning a passed-in array
William Leue
Posted: 10:34pm 22 Feb 2021
Here is a little test program that shows the problem.
You can re-dimension an array easily by using ERASE and then DIM again. However, if you pass in an array to a subroutine and try to re-dimension the passed-in array inside the subroutine, things go bad.
Peter, any comments? Thanks!
-Bill
' Test for redimensioning an array that is passed
' into a subroutine, as opposed to in the main program.
' It appears that something goes wrong if you try to
' redimension a passed-in array inside the subroutine.
' William M Leue 2/22/2021
option default integer
option base 1
' start with a dummy size
dim array(2, 2, 2)
print "dimension 1: " + str$(bound(array(), 1))
print "dimension 2: " + str$(bound(array(), 2))
print "dimension 3: " + str$(bound(array(), 3))
' Here we redimension the array in the main program.
' This works fine.
erase array
dim array(10, 10, 10)
print "After redimensioning in main program"
' Pass the array into the subroutine 'ReAllocate'
ReAllocate array()
end
' Here is the subroutine.
sub ReAllocate array()
 ' Verifying the dimensions of the passed-in array
 print "Looking at array inside the sub ReAllocate"
 ' Here is where things go wrong!
 ' The erase works but redimensioning produces the
 ' error: "Error in Line 43: array(5, 5, 5) already declared."
 erase array
 dim array(5, 5, 5)   '<=== This fails
 print "Looking at array inside the sub ReAllocate after redimensioning"
end sub
Posted: 10:41pm 22 Feb 2021
  Quote  Peter, any comments? Thanks!
Don't do it
William Leue
Posted: 12:07am 23 Feb 2021
Haha! Well, if necessary, I can code around the problem. (bug?)
But it's too bad, I have a good use case for wanting to do this.
-Bill
