Local Time 22:22 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CCS811 CO2 I2C sensor - CMM2
Nimue
Posted: 05:26pm 14 Feb 2021
Hi all
I have a ccs811 from Keystudio (https://wiki.keyestudio.com/KS0457_keyestudio_CCS811_Carbon_Dioxide_Air_Quality_Sensor   I can set up the sensor via Arduino using the libraries that ship with the device - and after burn in get sensible values.
For CMM2 I need to access the I2C directly -- and it's fair to say that I literally have no idea where to start
Assuming that I have SDA/SCL/VCC/Ground and that I've grounded "Wake" -- wired correctly -- and that the default address is: 0x5A  -- where do I start with figuring this out?
The "best" datasheet I can find on the CCS811 is here - https://cdn.sparkfun.com/datasheets/BreakoutBoards/CCS811_Programming_Guide.pdf
Any help / pointers greatly received ...
(Fingers crossed someone has already got one running ;-) )
Nim
Nimue
Posted: 05:34pm 14 Feb 2021
This was posted on the Annex Basic forum:
CCS811_READ:
' Bit 3 = Data Ready 0:no new Data 1:new Data
' Bit 0 Error dedection 0:no Error 1: Error on i2c or Sensor
i2c.writeRegByte CCS811_I2C_ADR, STATUS_REG , 0
i2c.ReqFrom CCS811_I2C_ADR,1
CCS811temp = i2c.read
If CCS811temp and 8 then                               'if Bit3 of status_register =1 then DATA_available
 i2c.writeRegByte CCS811_I2C_ADR, ALG_RESULT_DATA ,0  'selects the Result mailbox
 i2c.ReqFrom CCS811_I2C_ADR, 8
 for i = 1 to 8                                       'The Result mailbox contains  8 Bytes
   BUFFER(i)  = i2c.read
 next
 eCO2 = 256*BUFFER(1) + BUFFER(2)    'eCO2 ppm
 TVOC = 256*BUFFER(3) + BUFFER(4)    'eTVOC
else
 eCO2 = 0
 TVOC = 0
end if
i2c.writeRegByte CCS811_I2C_ADR, STATUS_REG , 0  --- apparently STATUS_REG         = &h00 ?? from the forum?
Might be useful....
Edited 2021-02-15 03:37 by Nimue
Nimue
Posted: 09:43pm 14 Feb 2021
After an enjoyable evening....
'CCS811 - Keystudio Sensor reading.
'Your sensor address might be diffent
'With help from Annex Wifi RDS forum
' Needs to run for a second to produce results
'Starts
dim as integer RDATA(7)
'Address of various buffers
CC811_ADR =     &h5A
APP_START_REG = &hF4
ALG_Results =   &h02
STATUS_REG =    &h00
MEAS_MOD_REG=   &h01
page write 1
'setup - this needs to happen once.
i2c open 100,1000
pause 10
'Change from BOOT to APP Mode
i2c write CC811_ADR,0,1,APP_START_REG
pause 10
'Set meaure"  << This needs to be passed ONCE before the sensor will read
i2c write CC811_ADR,0,2,MEAS_MOD_REG,16
pause 10
''Check the STATUS register (no actual check)
'i2c write CC811_ADR,0,1,STATUS_REG
'pause 10
i2c close
do
 i2c open 100,1000
 pause 20
 'Set meaure"
 'Check the results "envelope"
 i2c write CC811_ADR,0,1,ALG_Results
 pause 20
 i2c read CC811_ADR,0,8,RDATA()
 i2c close
'All the data in the resuls register  - uncomment to see
'for x= 0 to 7
'  print rdata(x),
'next x
print
 Print "ECO2 ",(256*RDATA(0))+RDATA(1), "TVOC ",(256*RDATA(2))+RDATA(3)
 page copy 1 to 0,B
 cls
 '250ms delay
 pause 250
loop
Not pretty, no GUI etc -- but the output for ECO2 and TVOC is consistent with sensor running on Arduino.
Now to tidy the code..
Nimue
Posted: 10:16pm 14 Feb 2021
Or check Geoff's web site for AirQuality.Bas......   https://geoffg.net/AirQualityMonitor.html
DOH!
Nimue
Posted: 03:25pm 16 Feb 2021
Great data sheet:  https://www.sciosense.com/wp-content/uploads/2020/01/SC-001232-DS-2-CCS811B-Datasheet-Revision-2.pdf
