Local Time 09:57 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: V5.07.00b12 - Various fixes
     Page 1 of 9
Posted: 11:32am 08 Feb 2021
V5.07.00b12 now available
http://geoffg.net/Downloads/Maximite/CMM2_Beta.zip
Fixes bug in CSUBs when used with OPTION RAM
Fixes bug in 12-bit colour modes missing last column
Fixes bug in edit when using large fonts with low resolution
Initialises the fast counter properly when using SETPIN 18,CIN
Increases the maximum files in a directory to 2000
GUI CURSOR x,y no longer displays the cursor if it is hidden - it just remembers the new location for a subsequent SHOW command
New facility for the fast count. You can now specify a Basic interrupt that will fire when the count exceeds &HFFFFFFFF. This allows you to trigger an interrupt when a specific number of counts have happened. See the example code for how this works
'connect pins 18 and 36
pwm 2,1000,50
setpin 18,cin,myint
pin(18)=&HFFFFFFFF-2047
timer=0
pause 1024
print hex$(pin(18))
do:loop
sub myint
print "done",timer
end sub
Edited 2021-02-08 21:33 by matherp
Chopperp
Posted: 12:29pm 08 Feb 2021
My download is coming up as 00b11.bin 30/01/2021.
ChopperP
Posted: 12:32pm 08 Feb 2021
Zip file contains V5.07.00b11
Posted: 12:49pm 08 Feb 2021
Try again - clear cache etc.
Chopperp
Posted: 01:05pm 08 Feb 2021
OK on another PC. Thanks
ChopperP
twofingers
Posted: 01:13pm 08 Feb 2021
THANKS Peter!
  Quote  Fixes bug in CSUBs when used with OPTION RAM
Works for me now.
Best regards
Michael
Posted: 02:56pm 08 Feb 2021
V5.07.00 is getting close to completion. The full list of changes from V5.06.00 is attached below and now also included as a readme.txt file in the download
  Quote  V5.07.00 has major new functionality to make your programming easier including full mouse integration into the filemanager and editor.
First PS2 mice are now supported connected directly to the CMM2. Many current USB mice still support the PS2 protocol and the current Microsoft Basic Optical Mouse is fully tested and recommended.
To make the connection the mouse clock line is connected to pin 33 of the CMM2 and the mouse data to pin 32. Both lines MUST be pulled up to 5V with 4K7 resistors
You can use exactly the same commands and functions to access and use a PS2 mouse as the Hobbytronic mouse except that the channel number for the PS2 mouse is zero
CONTROLLER MOUSE OPEN 0 [,[leftclickinterrupt] [,rightclickinterrupt] [,sensitivity]
Note the new optional sensitivity parameter. This allows you to tune the sensitivity of the Hobbytronic mice I/F by specifying a number between 0 and 10.
0 indicates that the default automaitic sensitivity should be used. Other values will explicitly set the sensitivity as per the Hobbytronic documentation.
For the PS2 mouse the sensitivity can be set between 0 and 8.
Values of 1-4 set the resolution of the mouse to 1,2, 4 or 8 counts/mm. Values 5-8 do the same but in addition enable mouse scaling which gives a non-linear relationship between speed and count.
See https://isdaman.com/alsos/hardware/mouse/ps2interface.htm for more details. NB: not all PS2 mice seem to implement these commands.
New sub-functions
MOUSE( T, 0) This tells you if a PS2 mouse has a scroll wheel (returns 3) or not (returns 0). Only works for PS2 mice (channel 0). For Hobbytronic mice will always return 0
MOUSE( D [,channel])
This allows you to detect a double click of the left mouse button and works for both the PS2 and Hobbytronic mice.
The algorithm say the two clicks must occur between 100 and 500 milliseconds apart.
The report via MOUSE(D) is then valid for 500mSec before it times out or until it is read.
In order to use a mouse in the filemanager and editor you need to tell the firmware to expect a mouse to be available:
OPTION MOUSE channel [,sensitivity]
This says that a mouse is connected to the specified channel (use channel 0 for a PS2 mouse) and the filemanager and editor will then expect and use the mouse.
To disable the mouse in the editor and filemanager use:
OPTION MOUSE OFF
You can enquire the status of the mouse option using MM.INFO(OPTION MOUSE) - reports -1 if no mouse is specified.
The mouse works as you would expect in both applications:
In the filemanager you can:
Left click on a line to position the cursor.
You can use the wheel to scroll up and down the file list
Right click in the top half of the screen to page up
Right click in the bottom half of the screen to page down
Double click to open/run a file (same as typing CR)
If you open an image you can return to the filemanager by left clicking the mouse.
In the editor you can:
Left click to position the edit cursor.
Scroll wheel to move up and down
Left click and hold down then move cursor to a new position and release the left button. The enclosed area will be selected for cut and paste.
Within cut and paste mode you can use the cursor and wheel to change the selection
To exit cut and paste without doing anything right click
Right click in top area of screen to scroll up (except in select mode)
Right click in bottom of screen to scroll down (except in select mode)
Left click at far left to scroll horizontally one character if the screen is scrolled horizontally
Left click at far right to scroll horizontally one character if the line is too long for the display
Double left click at far left to scroll to beginning of line if the screen is scrolled horizontally
Double left click at far right scroll horizontally to the end of line if the line is too long for the display
CLS now only clears the serial console when the write page os 1
New edit font OPTION EDIT FONT VERY LARGE for use with high resolution modes
Changed the horrible serif font 3 to a different one that is the same size
This release also supports a json parsing function. The json string to be parsed must be loaded into a LONGSTRING array
JSON$(array%(),string$) Returns a string representing a specific item out of the JSON input stored in the longstring array%()
e.g.
JSON$(a%(), "name")
JSON$(a%(), "coord.lat")
JSON$(a%(), "weather[0].description")
JSON$(a%(),"list[4].weather[0].description
Examples taken from api.openweathermap.org
Allow the user the ability to select which page(s) are displayed on the screen
Syntax is:
PAGE DISPLAY n [,page]
Normal example of use is:
PAGE DISPLAY 3. This says show on the screen the current contents of page 3.
The command does not impact the current write page
In 12 bit mode you can also use:
PAGE DISPAY 4,1
This sets the page to display for the top layer
The command executes in the next screen blanking period. When a program ends for any reason the normal display page 0 is restored
A new mode 14 is introduced which has the timings for 540P, same 960x540 as mode 12 but with no line duplication. If your monitor can handle it this is the best default mode for a widescreen monitor
Program profiling capability
To turn on or off the profiling use
OPTION PROFILING ON
OPTION PROFILING OFF
This is a permanent option but it defaults to OFF whenever new firmware is loaded.
With profiling on you will see a performance impact of about 5% caused by the profiling data collection which happens at the MMBasic statement level.
In addition you will see a reduction in available variable RAM of 512KB. Note that profiling and OPTION RAM are mutually incompatible.
With profiling enabled you can run your programs as usual and you should see no change in behaviour other than as mentioned above. You can see the way the program has run using the commands
LIST PROFILE
LIST PROFILE CSV
There are 5 comma-separated fields in the output
The first field is the number of times a given statement has been run
The second field is the average time in Microseconds taken to execute the statement
The third field is the crunched statement as stored in memory. This is quoted to make it easier to load into excel etc.
The fourth field is the filename in which the statement appears. This is blank if the statement is in the main program, otherwise it gives the filename of the include file in which the statement is to be found
The fifth and final field gives the line number of the statement in the source file.
When LIST PROFILE CSV is used a file is created in the same directory as the main program with the .BAS extension replaced with .CSV
LIST PROFILE can only be used at the command line
LIST PROFILE CSV can be used in a program allowing you to create and rename multiple files while a program is running if required
new operator for signed shift right
integervariable>>n' for unsigned shift right
integervariable>>>n' for signed shift right
A new fast settick mode is now available:
SETTICK FAST frequency, interruptroutine
This allows you to exceed the current maximum rate of 1 interrupt per millisecond (1000HZ) and has been tested up to 50KHz.
Obviously if the interrupt routine overruns the time available then interrupts will be lost.
If the program is executing a statement that takes longer than the time between interrupts the interrupts will be stacked.
Enhancement is to allow you to select the serial port to be used as the console.
OPTION CONSOLE PORT n
n can be 1, 2, or 3 (default). If this option is set all console output is directed to the specified com port. This allows easier remote operation using a wifi-uart or radio link.
Previously you would have had to remove the MCP2221A chip and connect the external I/F to the USB-B connector.
If the option is set to other than default then COM3 is available on the USB-B connector.
Posted: 03:40pm 08 Feb 2021
Looks good Peter,
Any chance of a response to: https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=13417
Edited 2021-02-09 01:40 by thwill
Posted: 03:49pm 08 Feb 2021
Think I did it - please check
Posted: 04:02pm 08 Feb 2021
  matherp said  Think I did it - please check
OK, I've checked my CMM2 (currently running b11) and it does indeed appear to have been fixed, THANKS.
I'm sure I upgraded to and tested with b11 just before writing that post though ... I'm too young to be having senior moments.
Anyway, thanks Peter.
panky
Posted: 01:15am 09 Feb 2021
Thanks Peter for the Fast Count fix, also for the interrupt capability - exactly what I need for a project I am working on. I understand your statement about implimenting CMM2 stuff into ArmMite H7 but I would really love to see the Fast count preset and interrupt included in it - the CMM2 is fantastic but an overkill for the instrument project I am working on.
Thanks,
Doug.
DevineTrash
Posted: 11:23pm 09 Feb 2021
I just tried to download but got a "file not found" error
Posted: 11:29pm 09 Feb 2021
Works for me. Clear browser cache or something.
Plasmamac
Posted: 09:27am 10 Feb 2021
Thanks a lot
Plasma
Schlowski
Posted: 08:58am 13 Feb 2021
Edit: post deleted, error on my side...
Edited 2021-02-13 19:29 by Schlowski
Posted: 10:26am 13 Feb 2021
V5.07.00b14 now available
Changes to PAGE DISPLAY
PAGE DISPAY 4,1
Note for modes 3 or 5 or 6 or 7 or 12 or 13 you can only select pages 0 or 1 for display in 8 or 16 bit colour and pages 0, 1, or 2 in 12-bit colour
To turn the display off use PAGE DISPLAY -1. To turn it back on select a valid display page - the contents of the video pages are not changed by this command
Edited 2021-02-13 20:32 by matherp
Posted: 10:19am 14 Feb 2021
V5.07.00b15 now available
Fixes bug in ON ERROR SKIP allowing errors in one additional command over the number specified
New Sub-commands
SAVE DATA fname$, address, size 'saves "size" bytes to file "fname$" starting from "address". Data is saved in raw binary format
LOAD DATA fname$, address 'loads the raw binary contents of file "fname$" and stores it in memory starting at "address"
Together these allow you to very easily save and restore the contents of an array or video page to and from disk. The code tries to protect you from crashing the system to the extent possible but there are many ways you can misuse the LOAD DATA command if you try
Edited 2021-02-14 20:23 by matherp
Plasmamac
Posted: 10:57am 14 Feb 2021
your support is fantastic. thx a lot
Plasma
jirsoft
Posted: 01:40pm 14 Feb 2021
  matherp said  V5.07.00b15 now available
New Sub-commands
Hi Peter,
this is simply super! It could be done with CSUB, but so it's much easier. Just one suggestion/request: can be in SAVE added flag for append? My favorite for use this is for example SAVE BMP (16 bpp) in the GRF.INC library, where I write header with PRINT# and then I could append chunk of graphic data...
Jiri
vegipete
Posted: 08:53pm 14 Feb 2021
Is it remotely possible for PAGE DISPLAY to refer to (a section of) the FRAMEBUFFER?
Also, could PAGE WRITE include a numerical value to refer to the FRAMEBUFFER. Maybe, say, 999? Or, gasp, -1? (This would be equivalent to FRAMEBUFFER WRITE.)
Lastly, I am getting an odd error with FRAMEBUFFER WINDOW when FRAMEBUFFER WRITE is active:
mode 2,12   ' 640x400, 7 pages
cls
framebuffer create 1600,400
framebuffer write
line 0,0,1599,399
' uncomment next line to make error go away
'page write 0
x = 0 : dx = 1
do
 framebuffer window x,0,0
 x = x + dx
 if x = 0 or x = 960 then dx = -dx
loop
Edited 2021-02-15 06:54 by vegipete
     Page 1 of 9
