Local Time 22:23 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : With bmp file, grey becomes white on F4 320x240 LCD
Posted: 04:10pm 07 Feb 2021
I downloaded some icons from https://openweathermap.org and cut and pasted them into a single bmp, and downloaded to my F4 to make sprites (blit buffers). When displayed, the grey areas indicating clouds display as white.
I went back to the PC and reduced the color depth to 24 bits in PaintshopPro, saved it and downloaded it, but the clouds still show up white.
What do I need to do to get them to show up as grey? (I've converted to png so I could upload to the forum.)
vegipete
Posted: 06:31pm 07 Feb 2021
Make the gray darker.
Posted: 07:52pm 07 Feb 2021
  vegipete said  Make the gray darker.
Clearly. The question is how?
mclout999
Posted: 08:47pm 07 Feb 2021
In your paint program of choice load them and flood fill with a different color.  Even windows paint can do it.
Posted: 08:56pm 07 Feb 2021
That has the clouds set to RGB(230,230,230)
Edited 2021-02-08 06:58 by TassyJim
Posted: 11:14pm 07 Feb 2021
Thank you, Jim. How did you do it? (Teach a man to fish ...)
Posted: 12:17am 08 Feb 2021
Windows paint
Edit colours to select a suitable colour
Use the fill tool - image of paint pot being poured.
Click in each cloud and the cloud changes to the selected colour.
Paint has an undo feature so it is safe to play around.
I don't bother with the newer versions - they look too kiddified for me.
Posted: 01:22am 08 Feb 2021
Thanks. I'll try it, rather than just using yours.
Posted: 12:48pm 08 Feb 2021
I also changed the sun to yellow rather than red. Much better. And learned a new technique. Thanks again, Jim.
