Local Time 11:55 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Check if input data is integer or not (MMX V5.0504)
AussieWombat
Posted: 02:20am 07 Feb 2021
Hi all,
I have an input statement, that has to be an integer.
If I type a word into the input, it accepts it.
I was going to use an if then statement to check if it is (NAN),
I am using
fontwidth:
Input "Width of Font? ",fwidth%
IF (fwidth% =0) then
print "not a number"
goto fontwidth
endif
but if they enter zero, that stuffs that up . Or should I add to the input statement.
Input "Width of Font?(1-255) ",fwidth%
regards
AussieWombat
Chopperp
Posted: 03:07am 07 Feb 2021
I did a quick prog. Needs refining
fwidth% = 0
Do While fwidth%  = 0
 Input "Width of string ", fwidth%
 Print fwidth%
Loop
Brian
ChopperP
Posted: 10:40am 07 Feb 2021
Brian's code is good but three extra points:
You use "IF (fwidth% =0) then" without an ENDIF.  This is why entering zero causes an error.  As an aside, when you are asking for help on this forum it would be worth giving a clear description and listing the full error message rather than just saying "stuffs that up".
If the user just hits Enter at the prompt fwidth% will be unchanged.  If this is not what you want it would be worth initialising fwidth% to some default value (ie, 0 as in Brian's code).
You do not need brackets around conditional tests (ie, (fwidth% =0)) but also they don't hurt.  I'm guessing that you come from a C background.
Posted: 02:18pm 07 Feb 2021
Assuming you don't want anything but digits i.e. no decimals...
fontwidth:
   Input "Width of Font? ",a$
While Len(a$)<1
For n=1 to len(a$)
   if instr(" 0123456789",Mid(a$,n,1)<2 then
       goto fontwidth
   endif
next
fwidth%=val(a$)
I always like to grab data as strings and then process into whatever form I need. Minimises errors because of data mis-matches and you maintain control of everything in the string. As an aside, I avoid Input - you drop into the guts of MMBasic while it is waiting for the enter key which is "blocking" i.e. it stops your code running (interrupts, timers etc)
One of my pet likes is to convert VB functions into MMBasic. I never did IsNumeric() as I never really saw much call for it, but now...  With it, you could simply have:
fontwidth:
If IsNumeric(a$) Then
   fwidth%=val(a$)
Else
   goto fontwidth
EndIf
Any IsNumeric() function would be pretty much the same as the first bit of code above, but with some sanity checking and switches to allow decimals (one) etc.
Happy to do it for you and add it to the library if you would like that.
You might also like to look at this Constrain() function
Edited 2021-02-08 00:32 by CaptainBoing
Schlowski
Posted: 02:37pm 07 Feb 2021
Isn't jumping with GOTO out of a FOR-NEXT loop without proper ending the loop critical?
I would assume that this leaves some sort of unresolved FOR-information on some sort of stack or so...
Posted: 02:42pm 07 Feb 2021
It is bad form, yes I agree and GoTo is seen as structured programming's arch-enemy. I wanted to make the code as "look-a-like" to the original so as not to stray too much and take away from the original query - hence following up with an example using a nice function - structure restored.
Regardless, MMBasic (at least on MM2 so I suspect all other platforms are the same as the core language hasn't been changed) is quite happy. True some languages use the stack for loops and this would as you suspect blow up memory, but not MMBasic (same with Do/Loop and Select/End Select). Internally they seem to act almost as if they are "aliases" for If/GoTo pairs, mimicking what CPUs do in the binary with test and Jump.
Try this bit of code below, just runs happily forever
Fred:
For n=1 To 1000
GoTo Fred
Next
Edited 2021-02-08 01:23 by CaptainBoing
Posted: 07:42pm 07 Feb 2021
For this problem, I prefer to use INKEY$ and prevent non-numeric characters from getting entered.
This is written for the CMM2 but shouldn't need much change for any MMBasic platform.
 ' text input routines
 ' option console serial ' to stop messing up the display
 CONST FALSE = 0
 CONST TRUE = NOT false
 'dim n$(10)
 'dim config$(10,3)
 DIM INTEGER tHt = MM.INFO(FONTHEIGHT), tWth = MM.INFO(FONTWIDTH)
 DIM FLOAT num
 'dim integer k
 CLS
 num = GetNum(10,10,"42")
 PRINT
 PRINT num
 ' Gets valid numeric input from user
 ' Parameters:
 ' Row, Col - location to echo input
 ' Initial$ - default value
FUNCTION GetNum(Col AS INTEGER, Row AS INTEGER,initial$)
 LOCAL result$, Kbd$
 LOCAL INTEGER Done
 Result$ = initial$
 Done = FALSE
 DO WHILE INKEY$ <> "": LOOP 'Clear keyboard buffer
 DO WHILE NOT Done
   TEXT col*tWth,Row*tHt,Result$+CHR$(95)+ "    ",lt,1,1
   DO
     Kbd$ = INKEY$
   LOOP UNTIL Kbd$ <> ""
   SELECT CASE Kbd$
     CASE CHR$(27)
       result$ = initial$
       done = true
     CASE "0","1","2","3","4","5","6","7","8", "9"
       Result$ = Result$ + Kbd$
     CASE "."
       IF INSTR(Result$, ".") = 0 THEN
       ELSE
         PLAY TONE 440,440,100
       END IF
     CASE CHR$(13),CHR$(9)
       Done = TRUE
     CASE CHR$(8)
       IF LEN(Result$) > 0 THEN
         Result$ = LEFT$(Result$, LEN(Result$) - 1)
       END IF
     CASE ELSE
       IF LEN(Kbd$) > 0 THEN
       END IF
   END SELECT
 LOOP
 TEXT col*tWth,Row*tHt,Result$+ "    ",lt,1,1
 GetNum = VAL(Result$)
END FUNCTION
END
AussieWombat
Posted: 06:58am 09 Feb 2021
Thanks all for the replies,
I was just going through some old programs I had written for the Maximite and CMM1, and trying to get them to work in the MMX V5.0504
They will probably never see the light of day, but I thought it would be a good exercise.
I like the approach of TassyJim, and use the inkey$, as then interupts would not be hindered.
It was for an old font creation program, but now we can all use TassyJims FontTweak program to create fonts.
Aussiewombat
