Forum Index : Microcontroller and PC projects : MMEdit Lost Find/Replace
Chopperp![]() Guru Joined: 03/01/2018 Location: AustraliaPosts: 1131 |
For TassyJim I removed one of the monitors from an older PC with MMEdit on it & now have lost the Find/Replace box. I'm assuming that the PC/MMEdit thinks it is on the monitor that is not there. It comes up in the Task Bar OK. Is there a simple way of getting it back onto the single monitor with the main program apart from reconnecting the other one & moving it across? Thanks Brian ChopperP |
Assuming MMEdit V4 In the data folder there is a file "mmedit4.inf" data folder location can be found from Help/About If you delete that file (with MMEdit shutdown), it will get recreated with the default settings. If you don't want to loose all of your settings, With MMEdit shut down, open the mmedit4.inf file with any text editor and find the section on locations [Locations] mainWinLoc = 1242 952 584 120 80 configWinLoc = 479 411 114 44 chatWinLoc = 812 783 1012 163 1 0 fileWinLoc = 763 652 601 90 HintWinLoc = 688 300 602 160 ReportWinLoc = 785 599 1003 185 FindWinLoc = 248 186 947 130 0 0 Delete the line "FindWinLoc" restart MMEdit Jim VK7JH MMedit |
Oops, Old PC, not used much. Will update to V4 Thanks Jim EDIT Updated OK Edited 2021-01-26 10:42 by Chopperp ChopperP |
