Local Time 23:31 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Matrix Inversion and Determinants
William Leue
Posted: 04:50pm 11 Jan 2021
Our excellent MATH firmware has some useful matrix and vector operations but does not currently have matrix inversion or determinant computation.
I needed these for a project, so I wrote routines to do both determinants and matrix inversion. I enclose my test program here.
Please don't mistake this for a robust, high-tech library routine! I do test for singular matrices before computing the inverse (using the determinant) but many other things can go wrong if your matrix is "ill-conditioned", which can mean any of several different problems, including "almost singular"; that is, having a non-zero but extremely small determinant. The Gauss-Jordan Elimination algorithm that I use is known to be numerically unstable for ill-conditioned matrices.
Enjoy!
-Bill
Math_Matrix_Inversion.zip
