Local Time 12:42 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Firmware 5.06.00 Error Duplicate Name
William Leue
Posted: 08:32pm 28 Dec 2020
A program that ran fine on 5.06.RC15 now gives me
Error: Duplicate Name
when I try to start it, and quits. Nothing else, no clue as to what might be duplicated. I know this was a bug in a previous release candidate, but I thought that was fixed. Shouldn't the error at least mention the name that is being duplicated?
-Bill
William Leue
Posted: 08:38pm 28 Dec 2020
Found it! I had two copies of a subroutine named 'Beep'. Got rid of the dupe and it all runs fine.
But...why doesn't the Error handler give me a clue as to what is duplicated?
-Bill
toml_12953
Posted: 10:34pm 28 Dec 2020
  William Leue said  Found it! I had two copies of a subroutine named 'Beep'. Got rid of the dupe and it all runs fine.
-Bill
Was Beep defined multiple times when you ran the program under 5.05? If so, I wonder why it wasn't caught back then.
RetroJoe
Posted: 12:39pm 29 Dec 2020
It would be nice if MMBasic was a little more verbose in error messages, but the “normal” process is to enter the editor (i.e. by typing “EDIT” at the command prompt) immediately after an error is displayed, in which case the cursor should be on the offending line of code. Was that not happening in your case?
It is curious why this error was not detected in RC15, or how your program ran successfully. AFAIK, the no dupe SUB names rule was always in effect, but maybe earlier versions just used the first occurrence of the SUB and ignored any others with that same name ? I’ll have to reread the 5.06 release notes...
Also remember that a subroutine or function name cannot be the same as a declared variable, nor the same as a built-in MMBasic command or function. Don’t believe that’s the problem here, but I figured a reminder was apropos :)
Edited 2020-12-29 22:40 by RetroJoe
Enjoy Every Sandwich / Joe P.
William Leue
Posted: 03:00pm 29 Dec 2020
What is interesting is that the duplicate routine name, in addition to generating the non-helpful error message, also gets the firmware confused a little. So after getting the error, if I type "edit" at the prompt, it responds with "Nothing to Edit".
Oh well, it's a very minor wart.
-Bill
toml_12953
Posted: 03:05pm 29 Dec 2020
  William Leue said  A program that ran fine on 5.06.RC15 now gives me
-Bill
How about posting the program so we can see if it affects our system?
Posted: 03:08pm 29 Dec 2020
It isn't affecting anything. The program fails parsing so isn't loaded into memory. Therefore there is nothing to edit
William Leue
Posted: 03:51pm 29 Dec 2020
Ah, thanks for the explanation, Peter! All is clear now.
-Bill
