Local Time 23:58 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Error messages in MMBASIC
envirotronics
Posted: 05:15am 21 Dec 2020
I am new to MMBASIC
Is there a dictionary of error messages explaining the meaning of each message or is it a case of best guess?
Posted: 08:39am 21 Dec 2020
Sorry, as far as I know no one has ever built a glossary.  The error text is meant to be self explanatory (and short).
Edited 2020-12-21 18:42 by Geoffg
Posted: 10:14am 21 Dec 2020
Error messages *usually* give a good indication but it's simply not possible to capture and document every permutation. Occasionally the error message can send you in the wrong direction because there are only so many scenarios that can be trapped. There are many little things that happen under the bonnet even in the simplest of statements that we aren't really privy to (that's why we use hi-level languages so we don't have to mess around with all that stuff).
An example of misdirection from a while back where I had an "out of memory" error while defining a variable. But it wasn't the variable itself that was the problem, it was a CASE statement (constructs use a bit of stack and I was right on the limit). It sent me off chasing a variable problem when it was really my code was too complex - too deep in lots of functions and loops and MMBasic simply ran out of stack space and burped out this memory at the point of a LOCAL... I put 2+2 together and came up with 17; yes I had run out of stack but it was nothing to do with the variable. It will come, I promise you and you have a huge crowd here who are very friendly and centuries of experience and knowledge.
A definitive guide would exaggerate misleading diagnostics because it would lead you away from thinking outside the box. Error messages are good but when they don't seem to make sense to have to "free reign" it a bit - and that's not the sort of thing that can be written down - it has to be learned and "get the knack" for it... a bit like English pronunciation or French gendering.
