Local Time 23:58 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : drawing a Circular gauge
envirotronics
Posted: 03:47am 21 Dec 2020
Can anyone provide a couple of lines of code to draw the GUI GAGE.
I just cannot get it to work.
Also, when the line of code is longer than the LCD do we just ignore the message :line of code too long" and keep coding?
palcal
Posted: 06:40am 21 Dec 2020
Don't know what platform you are using but look at Geoff's Projects-Micromite Backpack.
Posted: 08:29am 21 Dec 2020
This draws two gages.  The first is single colour while the second has green/yellow/red for increasing temperatures.
font 4, 1
GUI gauge #1, 150, 110, 100, RGB(white), 0, 0, 1000, 0, "l/h", RGB(cyan)
CtrlVal(#1) = 612
GUI gauge #2,150,310,100,RGB(white),0,0,100,1,"`C",RGB(green),50,RGB(yellow),75,RGB(red)
CtrlVal(#2) = 80
  envirotronics said  Also, when the line of code is longer than the LCD do we just ignore the message :line of code too long" and keep coding?
No.  Instead you can break the line in sections to edit it - then later reassembled it by deleting the line breaks.  This is tedious but there is a limit to what an editor embedded in a microcontroller can do.
Edited 2020-12-21 18:30 by Geoffg
envirotronics
Posted: 08:46am 21 Dec 2020
Thank you Geoff for your respectful and mentoring style assistance.
