Local Time 23:59 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: BLIT WRITE while pushing memory limits
vegipete
Posted: 10:05pm 20 Dec 2020
The following program errors in a way that to me seems odd:
mode 1,8
dim a$(200,100)  ' yes, use a huge amount of memory
blit read 64,0,0,100,200
blit write 64,0,0
For this particular memory usage, the program errors on line 4. This implies the chunk of screen memory has successfully been read into a buffer. However, it seems even more memory is needed to write the buffer back to the screen. Really?
Posted: 10:43pm 20 Dec 2020
  Quote  However, it seems even more memory is needed to write the buffer back to the screen. Really?
Yes
