Local Time 00:12 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: LZ77 file compression/decompression
epsilon
Posted: 03:32pm 18 Dec 2020
Hi all,
Attached is a file compression and decompression program for CMM2, and a matching Python implementation to run on a host machine.
The code is a straightforward port from Rich Geldreich's C implementation which can be found here:
https://gist.github.com/fogus/5401265
Usage:
- On CMM2:
*lz1 e <file> : encodes <file> into <file>.lz1
*lz1 d <file>.lz1 : decodes <file>.lz1 to <file>
- On Host:
python lz1 e <file> : encodes <file> into <file>.lz1
python lz1 d <file>.lz1 : decodes <file>.lz1 to <file>
I plan to include this as an option to MAR, Maximite Archiving Tool (https://github.com/epsilon537/mar_cmm2 ). Any similarity to tar is entirely coincidental.
Cheers,
Epsilon.
README.md:
LZ1 LZ77 encoder/decoder
Authors
Original C implementation by Rich Geldreich.
MMBasic and Python ports by Epsilon.
Current Version
0.1
ChangeLog
0.1: Initial version.
Description
lz1 performs LZ77 compression/decompression of a given input file.
Two compatible versions exist: lz1.bas for CMM2 and lz1.py for a Windows/MacOSX/Linux host.
The source code for the original C implementation can be found here:
Usage
CMM2:
Host:
Required CMM2 firmware version
V5.06.00
Required Python version
3.x
GitHub
https://github.com/epsilon537/lz1_cmm2
lz1.zip
Epsilon CMM2 projects
Plasmamac
Posted: 07:05am 19 Dec 2020
cool ! thx
Plasma
