Forum Index : Microcontroller and PC projects : Updated Colour Maximite 2 Firmware (Ver 5.06.00)
| Page 1 of 2 |
We have a new stable release version of the Colour Maximite 2's firmware and documentation available for download from https://geoffg.net/maximite.html (scroll to the bottom of the page). This is Ver 5.06.00 and is a significant release which wraps up all the changes made in the recent beta versions. These includes performance improvements, dozens of bug fixes and many new features including extended MATH and IMAGE commands and a beta version of the 3D graphics engine. This represents a huge effort by Peter Mather over the past four months with lots of input from the community on this forum. Congratulations to everyone involved. The user manual has been updated and includes change bars in the left margin to identify most changes from the previous version. The source code at http://mmbasic.com has been updated and if you have downloaded any previous versions of the source you can use the same link to download this version. Geoff Geoff Graham - http://geoffg.net |
| LeoNicolas Guru Joined: 07/10/2020 Location: CanadaPosts: 625 |
Congratulations @matherp and @geoffg for this amazing project and for all efforts to improve the CCM2 firmware and our loved MMBasic. |
| mclout999 Guru Joined: 05/07/2020 Location: United StatesPosts: 531 |
Thank you guys for the wonderful work. ![]() They call me Shai-Hulud (The maker) |
| Turbo46 Guru Joined: 24/12/2017 Location: AustraliaPosts: 1694 |
Thanks Geoff and Peter, Fantastic job! Thanks also to Panky for the graphics document and all the bug catchers and those who spurred Peter on to even greater heights. Bill Keep safe. Live long and prosper. |
| PeteCotton Guru Joined: 13/08/2020 Location: CanadaPosts: 669 |
Yes. Thank you guys. Seeing the speed of Peter's releases was awe-inspiring. I think a well earned rest is deserved. |
| romba6 Newbie Joined: 04/07/2020 Location: United KingdomPosts: 40 |
Much appreciated all the dedicated work that has gone into the software development and all the documentation which helps makes it it all meaningful!! |
| thwill Guru Joined: 16/09/2019 Location: United KingdomPosts: 4410 |
Congratulations from me too, lets hope for a period of stability. Someone give @matherp something unrelated to do ![]() Tom Edited 2020-12-15 20:19 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| Coresoap Newbie Joined: 27/11/2020 Location: GermanyPosts: 3 |
Congratulations, and thanks |
| epsilon Senior Member Joined: 30/07/2020 Location: BelgiumPosts: 255 |
A major milestone. Congratulations! Epsilon CMM2 projects |
| ChrisJournoud Newbie Joined: 12/10/2020 Location: FrancePosts: 20 |
A great opportunity for my CMM2 coming those days from micromite.org Congrats to @matherp and @geoffg for this great project. |
| elk1984 Senior Member Joined: 11/07/2020 Location: United KingdomPosts: 232 |
Thanks to everyone who's made this happen. I'm looking forward to patching at the weekend and getting stuck in! |
| mkopack73 Senior Member Joined: 03/07/2020 Location: United StatesPosts: 261 |
Great job guys! Can’t wait to load up the new firmware this weekend and play with it! |
| panky Guru Joined: 02/10/2012 Location: AustraliaPosts: 1145 |
+1 for all the hard work put in by Peter and Geoff to get the CMM2 to where it is today. Thanks to you both. For Geoff: on page 110 of the User Manual near the bottom of the page, the function MATH(CORREL ... seems to be displaced from the description and subsequently mis-aligns the following MATH descriptions. Doug. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
| jcwippler Newbie Joined: 29/10/2020 Location: NetherlandsPosts: 3 |
I'm trying to re-flash the CMM2 with this firmware (it arrived as v5.05). Using CMM2 pre-built (not the WaveShare board) and I'm on MacOS. I'm not able to put the CMM2 in DFU mode, Have opened up the unit and switched the BOOT0 jumper, but the CMM2 continues to show "MCP2221 USB-I2C/UART Combo" after a power cycle, pid/vid 0x00dd/0x04d8. What might be going wrong here? -jcw |
Ok, solved with a USB-A to USB-A cable - the other port. Mighty inconvenient to require a special cable, but yeah, it works. -jcw |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12186 |
The CMM2 is in DFU mode and the USB/UART won't change it is just a serial connection. The issue is whether/how MacOS can run DFU over a serial connection |
| jirsoft Guru Joined: 18/09/2020 Location: Czech RepublicPosts: 533 |
Hi, I'm very interested, how did you flash it with A-A cable on Mac? I'm able to flash it with A-B cable (virtual serial port) with CLI app: /Applications/STMicroelectronics/STM32Cube/STM32CubeProgrammer/STM32CubeProgrammer.app/Contents/MacOs/bin/STM32_Programmer_CLI -c Port=/dev/tty.usbserial-AD0JHH4Z P=NONE -W /Users/jirsoft/Downloads/Colour_Maximite_2_MMBasic\-2/CMM2V5.06.00.bin 0x08000000 -v (the bold need to be changed to right serial port) but it doesn't work with Piotr's Deluxe version (many errors). And I don't know the right parameters for A-A cable ![]() Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), Â CMM2.fun |
| William Leue Guru Joined: 03/07/2020 Location: United StatesPosts: 415 |
I loaded the new version (5.06.00) the other day on both of my CMM2's and it works great! Also the new manual is the best one yet. Thanks to Geoff and Peter for their awesome work! -Bill |
| Lou Senior Member Joined: 01/02/2014 Location: United StatesPosts: 229 |
Bill, Where did you get the instructions to upgrade your CMM2, did you use Appendix G in the manual ? I have some CMM2's from CG and need to upgrade from V5.05.05 to 5.06.00, I don't want to chance bricking the chip. Lou Microcontrollers - the other white meat |
You can't brick one due to any kind of failed update! The CPU chip has an internal ROM which handles updates. (I guess you can kill one with mains power or some such, though.) John |
| Page 1 of 2 |
