Local Time 00:26 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Audio sample playback from within MMBASIC
frnno967
Posted: 12:12am 10 Dec 2020
I'm toying around with having Maxiterm play a sound for every character RX/TX. I really want to have a sound like the one from Wargames, but I can't figure out the best way to accomplish the task.
It sounds pretty good if I play an MP3 file for each character but I would rather not add an additional file that must be present for the feature to work. Is there a way to encode the audio sample values within the program itself, then call a subroutine to play them every time I want the sound?
Or should I just bite the bullet and include the sound file and distribute both as a .zip? And if I go this route, what command is best for checking of the presence of a file before it is played?
Thanks!
Jay Crutti: Ham Radio Operator, K5JCJ. Computer Enthusiast. Musician. Engineer.
hitsware2
Posted: 01:46am 10 Dec 2020
How about PLAY SOUND ?
my site
frnno967
Posted: 03:17am 10 Dec 2020
  hitsware2 said  How about PLAY SOUND ?
The original sound is a bit too multitimbral for PLAY SOUND. I tried that at first but the limited number of voices (4) combined with envelope characteristics meant that at best it sounded like a pure tone, but usually was very choppy and not close to the intended sound. Maybe if there was some ADSR parameters I could make it work, but I also don't know enough about the original sound yet to re-create it.
vegipete
Posted: 03:27am 10 Dec 2020
You could convert that mp3 to a wav.
Then, look at the sound code in Martin Scragg's Max-E-Man pacman game.
Way down in the program, look for the "ReadWav" subroutine to see how how he loaded the sounds into arrays. In principle, you should be able to convert the array of sound data into data statement values.
The "MakeNoise" subroutine shows how to feed the array to the DAC.
It's gonna be big though - 10k or more perhaps.
hitsware2
Posted: 04:35am 10 Dec 2020
Do you require a single sound ,
or multiple frequencies ?
my site
frnno967
  vegipete said  You could convert that mp3 to a wav.
This is perfect. I can downsample the WAV file to a very small size and make it work, but just couldn't figure out the procedure to do it. Thanks for the advice!
