Local Time 00:27 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CSUBs in 5.06
jirsoft
Posted: 06:34pm 09 Dec 2020
Hi Peter,
when I'm trying to get CSUBs working in 5.06 FW, I'm crashing the CMM2 all the time. Do I need to change somehow the compilation of the CSUB? I'm not using ARMCFunctions.h and I have still arm-gcc-link.ld the same version (2826 byte long).
From this simple code (tried to fix ScrollingText demo):
void FixBytes(long long *scr, long long int *x, long long int *y, long long int *w, long long int *h, long long int *nc)
//'FixBytes screenAdr, X, Y, W, H, newColor
char *adr;
adr = (char *)scr;
for (int i = 0; i < 80000; i++)
*adr++ = i & 0xFF;
Called from MMBasic with first parameter:
dim integer page1Adr = MM.INFO(PAGE ADDRESS 1)
It crashes the CMM2. The CSUB is
CSUB FixBytes
 00000000
 'FixBytes
 4A042300 F8003801 33013F01 D1FA4293 BF004770 00013880
END CSUB
Jiri
Posted: 07:43pm 09 Dec 2020
The issue is the way you are passing scr
Try
void FixBytes(unsigned int *scr)
char *adr;
adr = (char *)scr[0];
*adr++ = i & 0xFF;
Also start CSUB development with optimisation off and only increase it when everything is working. Then you can see if it breaks anything
Edited 2020-12-10 05:58 by matherp
RCMAN
Posted: 01:43pm 10 Dec 2020
  matherp said  The issue is the way you are passing scr
Try
char *adr;
*adr++ = i & 0xFF;
Where can I read about using Csub in my code? And is this documentation current?
RC
Posted: 02:15pm 10 Dec 2020
https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=12289
Is as good as you are going to get
RCMAN
Posted: 03:23pm 10 Dec 2020
jirsoft
Posted: 06:34pm 10 Dec 2020
Try
char *adr;
*adr++ = i & 0xFF;
Thanks,
I will try it.
Jiri
