Local Time 13:12 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Array Question
RCMAN
Posted: 01:43am 09 Dec 2020
Hi
I am bring over my C code to CMM2 and I have looked at the docs but an not clear on what I am doing wrong. My C code is like this
#define MAPWIDTH        20  // width of map in tiles
#define MAPHEIGHT       15  // height of map in tiles
int Map[MAPHEIGHT][MAPWIDTH] =
{00,52,00,00,26,00,52,53,26,00,16,00,00,00,03,00,00,26,00,00},
{16,15,14,33,26,33,33,00,26,00,16,15,14,16,03,16,16,16,32,00},
{16,16,16,03,15,03,15,00,26,00,00,00,00,16,03,00,00,00,16,03},
{53,00,00,03,16,03,16,16,15,13,17,14,03,16,03,17,15,16,00,03},
{33,00,51,03,16,03,16,53,03,00,00,00,03,16,03,00,00,16,03,16},
{17,00,00,03,16,03,16,00,03,13,17,15,14,16,51,16,03,16,03,02},
{16,13,13,15,16,03,16,00,03,00,00,16,03,00,00,32,03,16,03,00},
{34,00,00,00,00,03,16,52,16,16,03,16,03,13,03,15,13,17,14,03},
{16,03,16,13,16,16,27,25,00,53,03,16,03,16,03,16,00,00,16,03},
{02,03,16,16,00,00,16,26,00,00,03,16,03,16,03,16,16,03,16,03},
{02,03,32,00,00,16,53,26,00,00,03,16,03,16,03,51,00,03,16,03},
{02,15,14,16,13,17,00,26,00,32,03,00,03,16,03,00,04,03,16,03},
{02,27,27,27,27,27,27,25,17,13,14,15,16,13,16,17,14,13,16,03},
{02,00,52,00,00,52,52,26,52,52,00,52,00,00,52,00,00,52,00,03},
{13,17,15,13,16,15,13,13,17,03,15,13,17,13,15,17,13,14,13,17}
In CMM2
DIM MapData(20,15)
data 00,52,00,00,26,00,52,53,26,00,16,00,00,00,03,00,00,26,00,00
etc
then below I do
for j = 0 to 20
 for i = 0 to 15
    read MapData(i,j)
 next i
next j
Is this correct?
RC
toml_12953
Posted: 02:08am 09 Dec 2020
  RCMAN said  Hi
In CMM2
DIM MapData(20,15)
etc
then below I do
for j = 0 to 20
 for i = 0 to 15
    read MapData(i,j)
 next i
next j
Is this correct?
RC
You're trying to read a 21 x 16 array but the data looks like it only has 20 x 15 data. Try this:
DIM MapData(19,14)
for j = 0 to 19
 for i = 0 to 14
    read MapData(i,j)
 next i
next j
Edited 2020-12-09 12:09 by toml_12953
LeoNicolas
Posted: 05:57am 09 Dec 2020
This is a common problem in Basic.
Defining an array with a size of 20 positions in C, Java, C#, etc:
int myArray[20] -> The array goes from 0 to 19.
In Basic
with "option base 0":
Dim myArray(19) -> The array goes from 0 to 19
with "option base 1":
Dim myArray(20) -> The array goes from 1 to 20
Edited 2020-12-09 15:58 by LeoNicolas
RCMAN
Posted: 11:54am 09 Dec 2020
This is what I have and it tells me it's out out bounds.
DIM integer MAPData(19,14)
data 16,15,14,33,26,33,33,00,26,00,16,15,14,16,03,16,16,16,32,00
data 16,16,16,03,15,03,15,00,26,00,00,00,00,16,03,00,00,00,16,03
data 53,00,00,03,16,03,16,16,15,13,17,14,03,16,03,17,15,16,00,03
data 33,00,51,03,16,03,16,53,03,00,00,00,03,16,03,00,00,16,03,16
data 17,00,00,03,16,03,16,00,03,13,17,15,14,16,51,16,03,16,03,02
data 16,13,13,15,16,03,16,00,03,00,00,16,03,00,00,32,03,16,03,00
data 34,00,00,00,00,03,16,52,16,16,03,16,03,13,03,15,13,17,14,03
data 16,03,16,13,16,16,27,25,00,53,03,16,03,16,03,16,00,00,16,03
data 02,03,16,16,00,00,16,26,00,00,03,16,03,16,03,16,16,03,16,03
data 02,03,32,00,00,16,53,26,00,00,03,16,03,16,03,51,00,03,16,03
data 02,15,14,16,13,17,00,26,00,32,03,00,03,16,03,00,04,03,16,03
data 02,27,27,27,27,27,27,25,17,13,14,15,16,13,16,17,14,13,16,03
data 02,00,52,00,00,52,52,26,52,52,00,52,00,00,52,00,00,52,00,03
data 13,17,15,13,16,15,13,13,17,03,15,13,17,13,15,17,13,14,13,17
for j = 0 to 19
 for i = 0 to 14
   read MAPData(i,j)
next i
next j
What's wrong now?
R
Posted: 12:04pm 09 Dec 2020
Your array indices are backwards
RCMAN
Posted: 12:05pm 09 Dec 2020
  matherp said  Your array indices are backwards
<FACE PALM>
Thank You
RC
