Forum Index : Microcontroller and PC projects : Armmite F4
| lew247 Guru Joined: 23/12/2015 Location: United KingdomPosts: 1709 |
I've been reading all the threads I can find after discovering This M4 thread As far as I can ascertain there is no manual for the F4 and have to use the H7 manual but Is there support in Armmite for the NRF24L01 module in Armmite M4? ie Wi-Fi access |
| JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4381 |
I think it's known as the Armmite F4 and so F4 thread (or 407VET6) might be better? Might work better in a web search? I use the H7 manual but had no reason to try the module you mention, sorry. What happens if you do? John |
I did try the search and Google search but no definitive answer I guess the only people who know are Matherp or anyone that used the module |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11892 |
The is no support for the NRF24L01 in any version of MMBasic. It would need writing in Basic |
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3881 |
You could do wget with wifi on esp8266 with annex and pass data to Armmite F4, but you'd have to write some stuff which you don't have to do yourself on the pi. There's no F4 manual that I have found, so I use the H7, but it appears to me that while JSON$ is in the H7 manual, it doesn't work on the F4 (isn't available--though I didn't try an "easy" example). I dug out a pi-z-w with mmbasic (sketch) yesterday, so if you'd like to post code and data received from wget, I can look at it. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Thanks, I've sent you a message |
