Forum Index : Microcontroller and PC projects : Which is better
| lew247 Guru Joined: 23/12/2015 Location: United KingdomPosts: 1709 |
I need to find a processor that uses the least amount of current as possible I was going to use the Armmite L4 along with a HC-12 to receive the data as it's relatively low power especially when sleeping However the FireBeetle ESP32 uses only 0.008 mA while hibernating and it has Wi-Fi and Bluetooth built in Any suggestions on anything lower power that can get data from Wi-Fi or Bluetooth? Ideally that can use either MM Basic or Annex Basic RDS |
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3881 |
Annex Basic RDS is available for the ESP32, but I don't know what the low-power characteristics are. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
For ESP32 deep sleep with annex: 0.253mA PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Thanks :) I'll stick with the STM32L4 then and just turn everything else off while it's sleeping |
