Local Time 13:38 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Framebuffer copies entire screen worth?
mkopack73
Posted: 04:28pm 23 Nov 2020
Hey gang,
Looking to make a little 2 person racing game with split screen - player 1 top, player 2 bottom.
I was thinking I could use a Framebuffer to set up the map, copying in various tiles from the track tileset to build up a map larger than the screen, and then was hoping I could use windows to copy just a portion over to the upper or lower sections of a page based on where Player 1 or PLayer 2 are on the map (their view will be centered on their car at all times).
It seems like the Framebuffer window will only copy an entire screen's worth, not a subset of that.
Should I use Blitter instead?  Can you use blitter on a framebuffer to then copy to a page?
Bsaically I want:
Framebuffer = whole map, larger than 1 screen
page#1 - my screen buffer where I build up the next frame and I want it split like this:
|    P1 view     |     - which is a small subset portion of the framebuffer
|    P2 view     |     - which is a different subset portion of the framebuffer
Edit:
Am I correct in assuming that I can just set up the framebuffer and build up the big track map in that, then use the BLIT READ and BLIT WRITE to copy from the framebuffer and past into the upper or lower portion of the page I want to build up the player's views on?
Edited 2020-11-24 02:34 by mkopack73
Posted: 06:57pm 23 Nov 2020
  Quote  Am I correct in assuming that I can just set up the framebuffer and build up the big track map in that, then use the BLIT READ and BLIT WRITE to copy from the framebuffer and past into the upper or lower portion of the page I want to build up the player's views on?
yes, but unless you need to re-write the same information multiple times just use BLIT rather than READ/WRITE
Basically BLIT and FRAMEBUFFER WINDOW do exactly the same thing except that when I know the whole page is being overwritten I can optimise the transfer slightly more efficiently
mkopack73
Posted: 10:38pm 23 Nov 2020
Wrote a test program and seem to have it working (although I need to mess with the size of the 2 windows onto the framebuffer I’m blitting over. )
