Local Time 13:38 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: V5.06.00b3: Limited HELP
Posted: 11:38am 22 Nov 2020
V5.06.00b3
http://geoffg.net/Downloads/Maximite/CMM2_Beta.zip
The version fixes a bug in drawing commands when an expression for one of the parameters is > 32 characters
In addition it includes a limited help capability
HELP [text]
e.g. HELP DO
This displays up to 3 lines of help that match the "text". text isn't quoted.
If text isn't specified you can type characters into the help command and the display will show up to three lines than match
You can use up arrow and down arrow  to move through matches (e.g. for things like MM.INFO)
Exit the help command with either ESC or F12
In addition the command can be called from within the editor using F12. In this case the HELP command is called with any characters under the cursor up to the next character that can't form part of a command or function name. So if the cursor is positioned on the 'D' of a DIM command the help will immediately show the syntax for DIM
The text in the help facility is that supplied by TassyJim (many thanks) but I will accept sensible improvements within the limit of one line per entry (Max 100 characters in MODE 1)
The intention of the facility is just to provide a quick check on command syntax and will never replace the written manual. In the picture I pressed F12 on the MATH command and then added the ' m' in the help dialogue to filter the many 'MATH' results
Edited 2020-11-22 21:43 by matherp
elk1984
Posted: 12:32pm 22 Nov 2020
Thanks for this addition, really useful.
Would it be possible to extend the editor help to paste a definition in at the active cursor position?  Not so much lazy as avoidance of fat fingers when transcribing.
vegipete
Posted: 08:16pm 22 Nov 2020
What fun. LunarLander has a subroutine named 'help'. Easy to fix.
More fun : Rocks in Space (my asteroids clone) is very broken, I don't know why yet.
First problem:
"math set -1, dstcl()" doesn't work with a negative value.
Edit: found another:
play modfile "RISsound.mod" locks up my CMM2 - needs the reset button to get it back.
Note: this mod file is 'silent' -  there is no actual pattern to play. "play modsample" was used for individual sound effects. Nothing strange happens if I select "RISsound.mod" from the File Manager - just the expected silence. This worked fine before.
Edited 2020-11-23 06:36 by vegipete
Sasquatch
Posted: 08:40pm 22 Nov 2020
Page OR_Pixels, Page AND_Pixels, Page XOR_Pixels are not working as before in 12bit and 16bit graphics modes.  The source pages are changed in some cases.
Try this test program:
'Test program creates overlaping squares on Page 1 and Page 2
'And then does logic operation to display combined image on page 0
'Then copies Page1, Page2 to Page0 after key press
'Mode 1,8  'Mode 1,8 works ok
'Mode 1,12 'Mode 1,12 Xor_Pixels looks like OR_Pixels? And Page 1 gets copy of Page 2 contents
         'And_Pixels Page 1 gets cleared?
         'Or_Pixels Page 1 gets copy of Page 2?
Mode 1,16 'Mode 1,16 Xor_Pixels Page 1 gets copy of Page 2?
Page Write 1
CLS
Box 200,200,200,200,,,RGB(White)
Page Write 2
CLS
Box 300,300,200,200,,,RGB(White)
Page Write 0
CLS
Page Xor_Pixels 1,2,0
'Page And_Pixels 1,2,0
'Page Or_Pixels 1,2,0
Do While Inkey$ = "" : Loop
Page Copy 1 TO 0
Page Copy 2 TO 0
-Carl
Sasquatch
Posted: 10:08pm 22 Nov 2020
First problem:
"math set 0-1, dstcl()"
Seems to work
-Carl
Sasquatch
Posted: 11:25pm 22 Nov 2020
Here is a screen-shot of vegipete's 3D Maze demo.  As you can see, there are artifacts from the prevously run program (Gauntlet).  This seems different than before? V5.06.00b3
Adding a CLS before loading the graphics to Page 2 fixes the problem.  I suppose it's a philosophical question about which Pages should be cleared when a program is run or a NEW command issued?
Edited 2020-11-23 09:26 by Sasquatch
-Carl
vegipete
Posted: 12:08am 23 Nov 2020
I thought I fixed that screen corruption long ago. Perhaps the fix is in my new version, with chests and ladders ... which I haven't released.
  Sasquatch said  I suppose it's a philosophical question about which Pages should be cleared when a program is run or a NEW command issued?
No philosophy required. The programmer is responsible for initializing all data structures. Period. I didn't in my 3D maze program. Bad me.
Just like the programmer is responsible for sanitizing all input and handling buffer under and overflow properly.
Sasquatch
Posted: 02:40am 23 Nov 2020
  vegipete said  I thought I fixed that screen corruption long ago. Perhaps the fix is in my new version, with chests and ladders ... which I haven't released.
While I can agree that initializing everything to a known state within a program is good practice, I wouldn't anticipate artifacts from a previously run program in an interpreted BASIC environment!
-Carl
vegipete
Posted: 03:48am 23 Nov 2020
I wonder if this particular case has something to do with transparency. I'll have to go look how I originally made the graphics images
Posted: 08:28am 23 Nov 2020
  Quote  "math set -1, dstcl()" doesn't work with a negative value.
I went one step too far in removing unnecessary spaces when I do the load. Forgot about unary operators - will fix
  Quote  play modfile "RISsound.mod" locks up my CMM2 - needs the reset button to get it back.
Please post file or link to program
  Quote  As you can see, there are artifacts from the previously run program (Gauntlet).  This seems different than before? V5.06.00b3
Only page 0 is cleared with a RUN same as before but the memory layout is different so you are seeing a different bit of uncleared memory - will look at clearing all video memory when RUN
  Quote  Page OR_Pixels, Page AND_Pixels, Page XOR_Pixels are not working as before in 12bit and 16bit graphics modes.
Typo in code - will fix
Other known issue is that PAGE commands AND, OR, XOR, and STITCH won't work properly in modes 3,5,6,7,12, and 13 if one of the pages is 0 (all colours) or 1 (just 12-bit). Also on the list to fix
mkopack73
Posted: 01:02pm 23 Nov 2020
  elk1984 said  Thanks for this addition, really useful.
Agreed this would be extremely helpful.  Keep us from screwing up the parameters, almost as good as auto completion.
RetroJoe
Posted: 01:11pm 23 Nov 2020
So, how do you guys envision this working? You type a valid command or function name  into the editor, press a certain key, and the editor pastes the parameter signature to the right of the cursor?
Edited 2020-11-23 23:11 by RetroJoe
Enjoy Every Sandwich / Joe P.
elk1984
Posted: 07:29pm 23 Nov 2020
  RetroJoe said  So, how do you guys envision this working? You type a valid command or function name  into the editor, press a certain key, and the editor pastes the parameter signature to the right of the cursor?
Basically as Peter has implemented today in 5.06b4.
