Local Time 13:38 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM+ ILI9488(3.5") "Touch hardware failure"
Andrew_G
Posted: 02:36am 22 Nov 2020
Hi all,
I'm trying to get my Silicon Chip MM+ LCD Backpack to work with an ILI9488(3.5") display and I get an error "Touch hardware failure".
- it occurs when I tap the second target in GUI Calibrate (GUI Test LCDPanel is fine)
- I've tried two 3.5" displays, each of which work on an SC LCD Backpack v3 (uses a  MM170)
(- I've retried a 2.8" ILI9341 display which works OK)
- MM+ Basic V5.05.02
- MM.Startup has "ILI9488 2, 23, 29, 1" and I'm using the MM+ version.
- I've done Option Touch 1,3 (which was OK for my 2.8" ILI9341 displays).
Any ideas?
Cheers,
Andrew
morgs67
Posted: 07:00am 22 Nov 2020
  Andrew_G said  Hi all,
Any ideas?
Cheers,
Andrew
Have you seen this?
www.thebackshed.com/forum/ViewTopic.php?TID=11419
Tony
Andrew_G
Posted: 09:13pm 22 Nov 2020
Tony,
Six posts and you have already been nominated for "Genius Of The Year" (2020).
Thank you, thank you, thank you!
Yes I had read it - but it hadn't sunk in (properly).
It took a few attempts (getting the "Restart the Micromite" right) but with the SDO(MISO) pin not connected it works!
Touch calibrates and the SD card works (so now all I have to do is work out the different pins for MM vs MM+).
Thanks again,
Andrew
Edited 2020-11-23 07:14 by Andrew_G
