Local Time 13:38 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Quick "project" creator
elk1984
Posted: 12:07am 22 Nov 2020
I have the following script in my path.   When I want to knock up a quick program with all of my defaults I can get the project ready with
*new-project <project-name>
I hope someone finds this useful - it isn't fancy (i.e. no error trapping ).  If anyone would like to finesse the code a bit more, feel free.  Comments welcome.
new-project.bas
OPTION EXPLICIT ON
OPTION DEFAULT NONE
OPTION BASE 0
DIM commandLine As String = MM.CMDLINE$
DIM templateLine As String = ""
DIM templateFolder As String = "/"+commandLine
IF LEN(commandLine)>0 THEN
 OPEN "/.new-structure" FOR INPUT AS #1
 mkdir templateFolder
 DO
   LINE INPUT #1, templateFolder
   IF LEN(templateFolder)>0 THEN
     templateFolder = Replace(templateFolder,"<name>",commandLine)
     mkdir "/"+templateFolder
   END IF
 LOOP UNTIL EOF(#1)
 OPEN "/.new-template" FOR INPUT AS #2
 OPEN  "/"+commandLine+"/"+commandLine+".bas" FOR OUTPUT AS #3
 DO
   LINE INPUT #2, templateLine
   templateLine = Replace(Replace(templateLine,"<name>",commandLine),"<date>",date$)
   PRINT #3, templateLine
 LOOP UNTIL EOF(#2)
 CLOSE #1
 CLOSE #2
 CLOSE #3
 CHDIR "/"+commandLine
ELSE
 PRINT
 PRINT "NEW-PROJECT"
 PRINT "-----------"
 PRINT
 PRINT "Creates a new project with default parameters"
 PRINT "Usage: NEW-PROJECT <program-name>"
END IF
END
FUNCTION Replace(inputString As String, textToReplace As String, replacementString As String) As String
 LOCAL foundPosition As Integer = 1
 LOCAL lastFoundPosition As Integer = 1
 LOCAL newString As String = ""
 LOCAL preFindString As String = ""
 LOCAL postFindString As String = ""
 lastFoundPosition=foundPosition
 foundPosition=INSTR(inputString, textToReplace)
 IF foundPosition > 0 THEN
   'Replace The Found Text
   preFindString=MID$(inputString,lastFoundPosition,foundPosition-1)
   postFindString = MID$(inputString,foundPosition+LEN(textToReplace),LEN(inputString)-foundPosition+LEN(textToReplace))
   newString=preFindString + replacementString + postFindString
   'Search for the next instance by recursing the string
   newString=Replace(newString, textToReplace, replacementString)
 ELSE
   newString=inputString
 END IF
 Replace=newString
END FUNCTION
Save this file as .new-structure in the SD Card root.
<name>/includes
<name>/resources
<name>/files
<name>/config
Save this file as .new-template in the SD Card root.  This is your template code.  The example include here refers to my Auto Backup program
'File       : <name>
'Created    : <date>
'MM Version :
OPTION EXPLICIT ON
OPTION DEFAULT NONE
OPTION BASE 0
#include "/!includes/libraries/sub-backup-program.inc"
DoBackup (10,0)
After running this program, you'll have a directory created in root of your SD card, with a default directory structure and a template.bas file
