Local Time 13:38 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Odd system freezing
elk1984
Posted: 12:09pm 21 Nov 2020
This program is to draw a grid, with a dot at the centre of each grid "cell".  It's running on 5.05.05 (so I appreciate this may be fixed in the RC firmware)
OPTION EXPLICIT ON
OPTION DEFAULT NONE
MODE 3,8
DIM gridSize As Integer  = 5
DIM lineWeight As Integer = 1
DIM lineColour As Integer = RGB(150,150,150)
DIM boxLeft As Integer = 10
DIM boxTop As Integer = 10
DIM boxCols As Integer  = 5
DIM boxRows As Integer  = 5
DIM boxWidth As Integer = (gridSize+lineWeight)*boxCols + lineWeight
DIM boxHeight As Integer = (gridSize+lineWeight)*boxRows + lineWeight
DIM boxLineWeight As Integer = 1
DIM boxLineColour As Integer = lineColour
DIM x As Integer = 0
DIM y As Integer = 0
PAGE WRITE 2
CLS
BOX boxLeft, boxTop, boxWidth, boxHeight, boxLineWeight, boxLineColour
IF lineWeight > 0 AND gridSize > 0 THEN
 DO
   LINE boxLeft+(x*(gridSize+lineWeight)),boxTop,boxLeft+(x*(gridSize+lineWeight)),boxTop+boxHeight-lineWeight, lineWeight, lineColour
   x=x+1
 LOOP UNTIL x > boxCols
 DO
   LINE boxLeft, boxTop+(y*(gridSize+lineWeight)), boxLeft+boxWidth-lineWeight, boxTop+(y*(gridSize+lineWeight)), lineWeight, lineColour
   y=y+1
 LOOP UNTIL y > boxRows
END IF
PAGE WRITE 0
BLIT boxLeft,boxTop,boxLeft,boxTop,boxWidth,boxHeight,2
'Colour the centre marker of each grid square
DIM cursorX As Integer = boxLeft+lineWeight
DIM cursorY As Integer = boxTop+lineWeight
FOR y=0 to boxRows-1
 FOR x=0 to boxCols-1
   PIXEL cursorX+(x*(gridSize+lineWeight))+(gridSize\2),cursorY+(y*(gridSize+lineWeight))+(gridSize\2),RGB(255,0,255)
 NEXT x
NEXT y
DO
LOOP UNTIL INKEY$<>""
I'm seeing some really strange behaviour with the Pixel line.  With the code above, my system hangs (to the point where I need to power off and remove the SD card to get the system to respond; but the line below works.
   PIXEL cursorX+(x*(gridSize+lineWeight))+(5\2),cursorY+(y*(gridSize+lineWeight))+(gridSize\2),RGB(255,0,255)
Posted: 12:50pm 21 Nov 2020
  elk1984 said  . . . It's running on 5.05.05 (so I appreciate this may be fixed in the RC firmware)
Surely there's little point in posting problems but not using the most recent release. Would anyone want matherp to spend his time checking out something which might not even be a problem in the current firmware?
Edited 2020-11-21 22:50 by lizby
Posted: 01:26pm 21 Nov 2020
It is a day one bug that is still there. The workaround is to assign the calculated x,y values to variables and use the variables to pass to the pixel command
elk1984
Posted: 01:54pm 21 Nov 2020
  matherp said  It is a day one bug that is still there. The workaround is to assign the calculated x,y values to variables and use the variables to pass to the pixel command
Thank you, I'm still finding my way around the Maximite so wasn't sure.  Strangely enough it only seems to happen with the X coordinate.  The code below works:
Is it advisable to calculate all parameters to the graphics commands, or is this confined to PIXEL?
Posted: 04:41pm 21 Nov 2020
Found it.
The bug occurred because the expression for x was > 32 characters. There is complex code for all the drawing routines that checks to see if you have passed an array e.g. x() or a normal expression. This check assumed the maximum length of a variable i.e. 32 characters but of course an expression could be more than 32 characters so bad thing happened.
The workaround is to make sure any expression is less than 32 characters until I release the next beta. This is why your modified version worked. I'll put a note in the errata for V5.05.05.
Thanks for finding this - took me a bit of time to understand but it is an important fix
Edited 2020-11-22 02:42 by matherp
elk1984
Posted: 04:47pm 21 Nov 2020
  matherp said  Thanks for finding this - took me a bit of time to understand but it is an important fix
Glad to have helped out!
Edited 2020-11-22 02:48 by elk1984
