Local Time 13:48 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Multidimensional Arrays
PilotPirx
Posted: 07:54pm 20 Nov 2020
I'm a cmm2 beginner and I have a question about multidimensional arrays.
How can I specify the content of a two-dimensional array, for example?
DIM array1%(1,2)=((1,2,3),(4,5,6)) 'gives an error
DIM array1%(1,2)=(1,2,3,4,5,6)     'works, but wrong sequence
array%(0,0) is 1
array%(1,0) is 2
'How to fill
DIM row%=1
DIM column%=2
dim array%(row%,column%)=(1,2,3,   'row 1
                         4,5,6)   'row 2
This gives an Error too. In the past, i programmed with C. This was easier to declare.
I found no examples for CMM2 basic.
Posted: 08:00pm 20 Nov 2020
  Quote  DIM array1%(1,2)=(1,2,3,4,5,6)     'works, but wrong sequence
Depends what you mean by wrong. The storage of arrays in MMBasic in memory is with the first index moving fastest, then the second, etc. So just re-order your values to match.
