Local Time 01:22 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : syntax error?
markboston36
Posted: 07:19pm 20 Nov 2020
ok so i decided to try some of the programs in the manual. the days program i get a syntax error on line 28 and for the life of me i cannot see what its complaining about unless there is an issue with the code.
' Example program to calculate the number of days between two dayes
OPTION EXPLICIT
OPTION DEFAULT NONE
TRACE ON
dim STRING s
dim FLOAT d1, d2
DO
 print : print "Enter the date as dd mmm yyyy"
 print "first date";
 input s
 d1 = GetDays(s)
 if d1 = 0 then print "invalid date:" : continue do
 print "second date";
 input s
 d2 = GetDays(s)
 IF d2 = 0 then print "invalid date!" : continue do
 print "Difference is" ABS(d2 - d1) " days"
loop
'calculate the number of days since 1/1/1900
function GetDays(d$) as float
 local string Month(11) = ("jan", "feb", "mar", "apr", "may", "jun", "jul", "aug", "sep", "oct", "nov", "dec")
 local float Days(11) = (0,31,59,90,120,151,181,212,243,273,304,334)
 local float day, mth, yr, s1, s2,
'find the seperating space character within a date
s1 = INSTR(d$, " ")
if si = 0 then exit function
s2 = INSTR(s1 + 1, d$, " ")
if s2 = 0 then exit function
'get the day month and year as numbers
day = VAL(MID$(d$, 1, s2 - 1)) - 1
if day < 0 or day > 30 then exit function
for mth = 0 to 11
 if LCASE$(MID$(d$, s1 + 1, 3)) = Month(mth) then exit for
next mth
if mth > 11 then exit function
yr = VAL(MID$(d$, s2 + 1)) - 1900
if yr < 1 or yr >= 200 then exit function
' calculate the number of days uncluding adjustment for leap years
GetDays = (yr * 365) + FIX((yr - 1) / 4)
if yr MOD 4 = 0 and mth >= 2 then GetDays = Getdays + 1
GetDays = GetDays + Days(mth) = day
end function
Posted: 07:33pm 20 Nov 2020
You have a spurious comma at the end of the line and the interpreter is looking for another variable name. Also check the function EPOCH for this application
Edited 2020-11-21 05:34 by matherp
markboston36
Posted: 08:33pm 20 Nov 2020
its always the easy ones that allude me. im looking for something complicated and it was a typo :P.
markboston36
Posted: 08:40pm 20 Nov 2020
ok now its running but its not doing what its suppose to. when i type in the first day i get a bunch of numbers then it says enter first date and keeps repeating.
markboston36
Posted: 08:56pm 20 Nov 2020
fixed that now im stuck in the first date loop. for some reason it thinks what im typing in is 0 because i keep getting invalid date.
Posted: 09:30pm 20 Nov 2020
I copied the program from the "Introduction..." PDF.
The only line I changed was to remove the linebreak in line 21
IT runs correctly and tells me I am 25044 days old.
(Time flys when you are having fun)
There will be a few typos in your code.
Posted: 09:35pm 20 Nov 2020
I see a typo si for s1
No doubt others.
Posted: 12:22am 21 Nov 2020
si instead of s1 on line 33
and
the second = should be a + on line 53
Posted: 04:39am 21 Nov 2020
This is the complete program (with no errors).
You should be able to copy and paste from this webpage.
' Example program to calculate the number of days between two dates
OPTION EXPLICIT
OPTION DEFAULT NONE
DIM STRING s
DIM FLOAT d1, d2
DO
 PRINT : PRINT "Enter the date as  dd mmm yyyy"
 PRINT " First date";
 INPUT s
 d1 = GetDays(s)
 IF d1 = 0 THEN PRINT "Invalid date!" : CONTINUE DO
 PRINT "Second date";
 INPUT s
 d2 = GetDays(s)
 IF d2 = 0 THEN PRINT "Invalid date!" : CONTINUE DO
 PRINT "Difference is" ABS(d2 - d1) " days"
LOOP
' Calculate the number of days since 1/1/1900
FUNCTION GetDays(d$) AS FLOAT
 LOCAL STRING Month(11) = "jan","feb","mar","apr","may","jun","jul","aug","sep","oct","nov","dec")
 LOCAL FLOAT Days(11) = (0,31,59,90,120,151,181,212,243,273,304,334)
 LOCAL FLOAT day, mth, yr, s1, s2
 ' Find the separating space character within a date
 s1 = INSTR(d$, " ")
 IF s1 = 0 THEN EXIT FUNCTION
 IF s2 = 0 THEN EXIT FUNCTION
 ' Get the day, month and year as numbers
 IF day < 0 OR day > 30 THEN EXIT FUNCTION
 FOR mth = 0 TO 11
   IF LCASE$(MID$(d$, s1 + 1, 3)) = Month(mth) THEN EXIT FOR
 NEXT mth
 IF mth > 11 THEN EXIT FUNCTION
 IF yr < 1 OR yr >= 200 THEN EXIT FUNCTION
 ' Calculate the number of days including adjustment for leap years
 IF yr MOD 4 = 0 AND mth >= 2 THEN GetDays = GetDays + 1
 GetDays = GetDays + Days(mth) + day
END FUNCTION
markboston36
Posted: 07:45pm 21 Nov 2020
amazing how one typo can cause a big issue. thanks for all your help guys.
