Local Time 01:56 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 5.05.06RC18 on CMM2 - please HELP
jirsoft
Posted: 12:52pm 16 Nov 2020
I have issue with the 5.05.06RC18. Since error in my program (I copied SUB to change later name of copy to new one), I'm getting all the time
Error in line 1200: Duplicate name
Problem is, I can't do anything, NEW, CPU RESTART, UPDATE FIRMWARE... all the time the same error.
What can I do? When I reset CMM2 on the back connector, it will be empty? Can I then update firmware through A-B cable?
My model is 400 MHz without  Waveshare card...
Jiri
Posted: 12:56pm 16 Nov 2020
  Quote  When I reset CMM2 on the back connector, it will be empty?
No: it just deletes the program and resets the options to default. Nothing you can do will stop you being able to upload new firmware as this uses a bootstrap which is part of the chip itself.
This bug will be fixed in RC20 which will be out today
Edited 2020-11-16 22:56 by matherp
jirsoft
Posted: 01:03pm 16 Nov 2020
Thanks Pater,
I set the jumper to PROGRAM, updated FW to RC19 and after jumper to RUN everything works...
Jiri
