Local Time 21:39 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Is there a way to call the TEXT command from a CSUB?
epsilon
Posted: 03:46pm 12 Nov 2020
Hi all,
Is there a way to invoke the TEXT command from a CSUB?
I don't see any candidates in ARMCFunctions.h (FW ver 5.05.05).
TEXT X, Y, STRING, ALIGNMENT, FONT, SCALE, C, BC
Thanks for any help,
Epsilon/Ruben.
Epsilon CMM2 projects
Posted: 04:28pm 12 Nov 2020
If you download and install RC17 again there is now support for a call to RunBasicSub
This allows you to create a C string which contains any Basic command and then execute it from a C Function. This idea was created for the PICs by Geoff and I personally have never used it and it is completely untested on the CMM2
IMPORTANT the C string must be terminated by two zero characters and not just one
Edited 2020-11-13 02:33 by matherp
Posted: 05:51pm 12 Nov 2020
  matherp said  RC17 ... RunBasicSub ... This allows you to create a C string which contains any Basic command and then execute it from a C Function. This idea was created for the PICs by Geoff and I personally have never used it and it is completely untested on the CMM2
Can you explain this more fully or link to an explanation?
epsilon
Posted: 05:58pm 12 Nov 2020
Thank you for the quick response Peter. Do you know if RunBasicSub has access to the environment from which the calling CSUB was invoked, i.e. can I reference MMBasic locals and globals in that C string, or should I stick to immediates only?
Posted: 06:56pm 12 Nov 2020
  Quote  Do you know if RunBasicSub has access to the environment from which the calling CSUB was invoked, i.e. can I reference MMBasic locals and globals in that C string, or should I stick to immediates only?
Why not try it and see. Start simple and see what, if anything, works
epsilon
Posted: 11:08am 03 Mar 2021
I finally gave this a try and am happy to report that it's working well.
I'm making a call-out from a CSUB to an MMBasic SUB and pass along one parameter.
The MMBasic code looks like this:
DIM wm_draw_callout_arg%
SUB WM_DRAW_OBJ_DRAW_CALLOUT
 Object_draw(wm_draw_callout_arg%, 1)
END SUB
CSUB wm_draw_csub INTEGER, INTEGER, STRING, INTEGER
 00000000
 4FF0E92D F44F4C96 68097A48 0B00F04F 68066824 68E06825 FA06FB0A 07C1EB05
 00C6EB00 8B02ED2D 921
END CSUB
wm_draw_csub updates_lid%, wm_view%, "WM_DRAW_OBJ_DRAW_CALLOUT"+CHR$(0), wm_draw_callout_arg%
The call-out in the C code looks like this:
#include "ARMCFunctions.h"
void wm_draw_csub(long long *updates_lidp, long long *wm_viewp, char *callout_sub, long long *callout_arg) {
 *callout_arg = current_object;
 RunBasicSub(callout_sub+1);
A few details to keep in mind:
- The string referencing the Basic sub has to be all capitals.
- You have to append an additional 0 to that string. That was mentioned before.
- In the C code, add one to the string pointer. MMBasic strings have the string length in the first byte, C strings don't, so you have to move the point past that first byte.
- You can't just do this:
  RunBasicSub("WM_DRAW_OBJ_DRAW_CALLOUT\0");
 The C compiler would put the string literal in the data segment and that doesn't get included in CSUBs. There might be a way around this. I vaguely remember the original CSUB/CFunction thread talked about it. I prefer passing in the string.
Posted: 07:20pm 03 Mar 2021
  Quote  Please tell me that this is a problem with a known solution ... and point me at that solution.
For example if necessary can we do this:
char foo[] = "foo";
and then use variable foo instead of literal "foo".
As my understanding is that this should cause the generated binary to store "foo" on the stack and not in a read-only data section.
Edited 2021-03-04 05:48 by thwill
Posted: 07:45pm 03 Mar 2021
See my second post here
Posted: 11:46pm 03 Mar 2021
Thanks Peter. Looks "odd" , but if it works then who am I to complain.
