Local Time 01:57 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Updating Firmware Question
William Leue
Posted: 08:23pm 09 Nov 2020
I want to update the firmware on my CMM2 from 5.05.05 to 5.05.06RC15. It is still necessary to change the jumper on the PCB? (I have the version with the CPU on the MOBO, no Waveshare board.)
I have a vague and possibly false memory of there being an update to the procedure that is not in the manual, but I may be wrong.
Thanks!
-Bill
Posted: 08:29pm 09 Nov 2020
Syntax:
UPDATE FIRMWARE
Description:
Switch the STM32 CPU into firmware update mode.
This is the same as switching the BOOT CONFIG switch on the Waveshare CPU board to SYSTEM and allows for quick firmware updates without opening the Maximite's case.
You should cycle the power following a firmware update or if this command was accidentally used.
This will return the STM32 CPU to normal mode.
William Leue
Posted: 08:40pm 09 Nov 2020
Thanks, TassyJim! I knew there was a command, I just could not remember it. And of course, it is indeed in the latest manual in the commands listing. I note, however, that this command is NOT described in the section at the end of the manual on how to update the firmware.
Oh, and the ERASE command documentation is still sadly missing in the manual.
-Bill
Posted: 08:58pm 09 Nov 2020
I can't guarantee it's accuracy or being totally up-to-date.
Peter moves too quickly for me, but I do try to keep up...
https://www.c-com.com.au/mmhelp/index.htm
The pages are intended to cover all Maximite/Micromite variants so there are pages that are not relevant to the CMM2.
William Leue
Posted: 09:29pm 09 Nov 2020
I successfully updated the firmware but the UPDATE_FIRMWARE command did not seem to work; the STMCubeProgrammer was unable to connect to the CMM2 via USB and the A-to-A cable.
So instead I opened the case and moved the jumper from Run to Program. I was then able to do the firmware update with no problems.
-Bill
Turbo46
Posted: 03:47am 10 Nov 2020
I don't think the UPDATE FIRMWARE is explained fully in the Manual. After issuing the command you need to maintain power to the CMM2. But it's not wise to power it from a wall wart while connecting it to the PC or you may damage the PC's USB port!!!
This method works for me:
- Power the CMM2 from the PC (or USB hub) with the USB A to B cable
- Issue the UPDATE FIRMWARE command with the USB keyboard
- Replace the USB keyboard with the USB A to A cable and plug it into the PC (or hub).
- The PC will now recognise the USB A to A cable input.
- Use the STM32CubeProgrammer to program the CMM2
- Disconnect both cables to the CMM2.
- Reconnect the power and the keyboard to the CMM2 in your usual fashion.
jirsoft
Posted: 10:27am 10 Nov 2020
isn't easier to update through A-B cable (virtual serial port)? It's a little bit slower (30 sec vs 150 sec), but you don't need to change cable and once in a while are those lost 2 minutes acceptable...
Jiri
William Leue
Posted: 10:49am 10 Nov 2020
Thanks for the detailed instructions, Bill! Yes, I was being stupid: I should have realized that power has to be applied continuously to the CMM2 for the UPDATE FIRMWARE command to work.
Jiri, I have never seen any instrucions on how to do a firmware update using the
A-B cable, so that's why I never tried it.
-Bill
Posted: 10:56am 10 Nov 2020
  William Leue said  Thanks for the detailed instructions, Bill! Yes, I was being stupid: I should have realized that power has to be applied continuously to the CMM2 for the UPDATE FIRMWARE command to work.
-Bill
The A-B method is documented in the manual as the "Alternative Method" (p123 of the version I've got) and is also my preferred solution as it involves no plugging/unplugging of cables since the A-B is already connected from the CMM2 to the PC (for serial comms). Like Jiri says it's a bit slower, but I'm always happy for another excuse to make a cup of tea.
Edited 2020-11-10 20:57 by thwill
