Local Time 14:20 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Of mice and men err ... I2C
Posted: 10:06am 20 Oct 2020
Hi All,
Probably best addressed to Peter, but with the adoption of USB mouse on an I2C port does configuring for a mouse on I2C then exclude that I2C port for use for other I2C devices?
Can the USB mouse live on the same port as the NunChuk and both work?
Or does each USB (hobbytronics or other) have to have its own I2C port?
MICK
Posted: 02:05pm 20 Oct 2020
  Quote  Can the USB mouse live on the same port as the NunChuk and both work?
Not now but will be able to
You can use any other I2C device on the same port but don't "open" the port - it will already be open at 100KHz baud rate
Posted: 12:24pm 21 Oct 2020
Thanks Peter,
Great news..
I think it’s nearly time for you to take a holiday.. you must be darn near worn out with the amount of code you create..
I want you to know your efforts are appreciated.
MICK
