Local Time 14:20 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Has anyone got
lew247
Posted: 12:46pm 18 Oct 2020
I'm after some older versions of Picromite
I'm trying to find a version that BLIT and longstring works
I'm looking for
2018-11-16_222927_mmbasicSTRETCH.zip
2018-09-27_222719_mmbasicSTRETCH.zip  2nd version with fixes
or any versions after 5.4.20 where both Blit and Longstring works
I'm using Stretch and have no interest in updating it to Buster or anything
I "think" these are the only versions between 5.4.20 where Longstring was added and 5.05.01 where I know Blit does not work
The versions listed on the forum are not available to dowload anymore
mclout999
Posted: 06:51pm 18 Oct 2020
  lew247 said  I'm after some older versions of Picromite
I'm looking for
 I was thinking of using one of my PIs but never did. I found these them all over the forum hope they help. I ziped what I had up. those 2 are in there.
RASPI.zip
lew247
Posted: 06:59pm 18 Oct 2020
RASPI.zip
Thanks   not sure if they are any of the ones I'm after but I'll definitely check them out and let you know
The pi works brilliantly with MM it's a shame it's been retired
lew247
Posted: 07:43pm 18 Oct 2020
Thanks to both Lizby and mclout999 for their help with the older versions but unfortunately it didn't work.
Peter if you'r watching this
is there any easy way for me to modify version 5/4/16 to make longstring work?
5.4.16 both blit and longstring works but 5.4.21 upwords longstring works but blit doesn't
I've tried every version I can find from 5.4.21 upwards
led-bloon
Posted: 08:58pm 18 Oct 2020
I have most versions including:
2018-09-23_214847_5.4.21stretch
2018-09-24_232642_mmbasicstretch
2018-09-26_032429_mmbasicstretch
2018-09-27_222719_mmbasicstretch
2018-11-15_224828_mmbasicstretch
Name your poison
led
edit: Added one more
Stretch MMBasic
edit2: All in one zip file
Edited 2020-10-19 07:33 by led-bloon
Miss you George
lew247
Posted: 08:45am 19 Oct 2020
I made an error 2 posts up
5.4.16  blit works but longstring does not work but 5.4.21 upwards longstring works but blit doesn't
is there any easy way for me to modify version 5.4.16 to make longstring work?
Edited 2020-10-19 18:46 by lew247
Posted: 08:53am 19 Oct 2020
There is no change in the code for longstring or blit between these versions. This highlights the whole issue with the Picromite. It seems impossible to build a reliable version for any given combination of Raspbian and Pi type. Old version can't be modified as I don't have copies of older source - sorry.
lew247
Posted: 11:13am 19 Oct 2020
Thanks Peter
You were right obviously longstring does work but the versions after 5.4.20 the amount of data longstring can handle was increased
Blit for some reason doesn't work after 4.4.16 but I'll just use the earlier version
not to worry I'll try and reduce the amount of data needed
