Local Time 01:21 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pipe functionality
panky
Posted: 01:43am 18 Oct 2020
Can anyone suggest a way in which I can 'pipe' the console output to a string variable?
Eg. if I want to send the output of an OPTION LIST command to a variable?
I know I can capture it with teraterm or similar but I would like to be able to do it internally in MMBasic.
Doug.
vegipete
Posted: 04:01am 18 Oct 2020
I was thinking similar.
If we knew where the serial transmit buffer was in memory, we could peek into it immediately after "OPTION LIST"
CircuitGizmos
Posted: 04:17pm 18 Oct 2020
That would be a really nice feature.
Posted: 04:22pm 18 Oct 2020
Use MM.INFO(OPTION option). If any options that make sense are missing I'll add them
panky
Posted: 12:09am 19 Oct 2020
Thanks Peter,
I was thinking of a more general usage. When I am developing a program, one of the tools I use to debug the program is to intersperse PRINT variable statements at strategic points so I can see what is going wrong
This works fine when connected to a PC - the console output shows these as well as error messages without screwing up the graphics display. In a standalone situation however, this is hard to achieve (I have used the method where I create a log file and dump the progress/error statements into that but it is messy and time consuming).
I was hoping there may be an easy method already available of diverting the console output to either a string/longstring or file for analysis on a temporary basis -  a bit like TRACE ON/TRACE OFF (and, in fact this would allow TRACE ON output to be collected for analysis).
Thanks for a great program and all the support you give,
Doug.
MustardMan
Posted: 01:58am 19 Nov 2020
A few weeks ago I came across this video (about 20 minutes long) while looking for something else: Realtime debugging using serial decode
Although I've been doing embedded for more than two decades, it talks about an idea that I'd never even thought of: how to extract data from an embedded system without having to resort to pushing stuff to a console.
Sure, the data might not be as convenient as a nicely formatted string on a terminal emulator, but you can get the data out real-time if need be, and for debugging that can be a life saver.
I really don't like pushing videos, but this one was a real gem!
Cheers,
Edited 2020-11-19 13:33 by MustardMan
