Local Time 14:20 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Plotter package a la HP9800-series BASIC
NPHighview
Posted: 05:49am 17 Oct 2020
To become familiar with CMM2 and mmBasic, I've written a little plotter package that generates scaled 2D plots with axis labeling and (naive) clipping.  Two sample plots get generated by the "Main Program" code after all the subs and functions.  I've commented the code fairly diligently.  Please let me know if this is of any interest.
' plotplan.bas - HP9800-style plotting on the CMM2
'                This should be fairly mode-independent.
'                Note use of OPTION Y_AXIS UP to place 0 at the bottom.
'                Steve "NPHighview" Johnson      October 2020
'                Please contact me via TheBackShed Forum for any questions
'                Public Domain - Free / Unrestricted Public Use
'                              Set Up Environment
OPTION BASE 0 : OPTION EXPLICIT
OPTION ANGLE DEGREES
OPTION Y_AXIS UP
DIM INTEGER hres%, vres%, vmode%, vdepth%, x%, y%, i%, j%
DIM STRING key$, title$, x_label$, y_label, halign$(2), valign$(2)
DIM FLOAT defaultMode
DIM STRING x_lbl$, y_lbl$
' Naming Convention:     ph: Physical    gr: Graph    tl: Title Box    sc: Scaled
DIM INTEGER ph_x_min, ph_x_max, ph_x_ctr, ph_x_ext, ph_y_min, ph_y_max, ph_y_ctr, ph_y_ext  ' Physical dimensions
DIM INTEGER gr_x_min, gr_x_max, gr_x_ctr, gr_x_ext, gr_y_min, gr_y_max, gr_y_ctr, gr_y_ext  ' Graph dimensions
DIM INTEGER tl_x_min, tl_x_max, tl_x_ctr, tl_x_ext, tl_y_min, tl_y_max, tl_y_ctr, tl_y_ext  ' Title dimensions
DIM FLOAT sc_x, sc_y, last_sc_x, last_sc_y                 ' Scaled graph parameters.  Displays in physical graph area
DIM FLOAT sc_x_div, sc_x_min, sc_x_max, sc_x_inc, sc_x_ext
DIM FLOAT sc_y_div, sc_y_min, sc_y_max, sc_y_inc, sc_y_ext
DIM FLOAT theta, phi, x_3d, y_3d, z_3d, x_2d, y_2d
DIM INTEGER red_val, grn_val, blu_val, col_val
'                            Define functions and subs
FUNCTION LOG10(v) as FLOAT           ' returns logarithm base 10 of input value
 IF v <= 0.0 THEN LOG10 = -9.99E19  ' truncate at zero'
 LOG10 = log(v)/log(10)             ' works regardless of the base for mmBasic's log function
END FUNCTION
SUB SetPlotParams screenMode, colorDepth  ' Establish plot params based on video mode
 LOCAL STRING Mode_Depth                 ' Best if used with high-res modes'
 if screenMode < 1 OR screenMode > 13 then EXIT SUB else screenMode = INT(screenMode)
 if colorDepth < 8 OR colorDepth > 16 then EXIT SUB else colorDepth = INT(colorDepth)
 if screenMode = 9 AND colorDepth = 12 then colorDepth = 8     ' OK, mode 9 is weird
 Mode screenMode,colorDepth    ' Set video mode and color depth
                               ' Must set the mode to get the resolutions from MM.
 CLS
 hres% = MM.hres               ' get the actual horizontal resolution from the hardware
 vres% = MM.vres               ' get the actual vertical   resolution from the hardware
 defaultMode = MM.INFO(MODE)   ' get the actual video mode            from the hardware
' Based on screen mode, set all of the plotter parameters
 ph_x_min =   0 : ph_x_max = hres%-1 : ph_x_ctr = INT(hres%/2) : ph_x_ext = hres%
 ph_y_min =   0 : ph_y_max = vres%-1 : ph_y_ctr = INT(vres%/2) : ph_y_ext = vres%
' Graph dimensions
 gr_x_min = 100                   ' relatively arbitrary - leaves room for Y axis label and Major Axis values
 gr_x_max = hres% - 20            ' leaves room on the right.  May not be needed
 gr_x_ext = gr_x_max - gr_x_min
 gr_x_ctr = gr_x_min + gr_x_ext/2
 gr_y_min = 100                   ' relatively arbitrary - leaves room for X axis label, tick values and status line
 gr_y_max = vres% - 75            ' leaves room on top for the graph Title
 gr_y_ext = gr_y_max - gr_y_min
 gr_y_ctr = gr_y_min + gr_y_ext/2
' Title dimensions
 tl_x_min = gr_x_min
 tl_x_max = gr_x_max
 tl_x_ctr = gr_x_ctr
 tl_x_ext = gr_x_max - gr_x_min
 tl_y_min = vres% - 50            ' relatively arbitrary - room on top of title.  May not be needed
 tl_y_max = vres%                 ' a little space between title and graph area
 tl_y_ext = tl_y_max - tl_y_min
 tl_y_ctr = tl_y_min + tl_y_ext/2
' Scaled Operations
 last_sc_x = 0
 last_sc_y = 0
END SUB
SUB DrawPlotArea xmin, xmax, ymin, ymax, xjdiv, yjdiv, xndiv, yndiv    ' draw background,  axes, labels of plot area.
 LOCAL x, y, xjinc, yjinc, xninc, yninc, xval, yval    ' floats.  "j" for maJor, "n" for miNor tic marks
 LOCAL sc_x_e10, sc_y_e10, xval_trnc, yval_trnc        ' truncated (base 10) scaled extents and values
 LOCAL STRING xval_disp, yval_disp                     ' truncated string values
 ' Set scaled graph values from parameters passed here.  No need to bother user with all this stuff
 sc_x_min = xmin
 sc_x_max = xmax
 sc_y_min = ymin
 sc_y_max = ymax
 sc_x_ext = xmax - xmin                  ' ext is "extent"
 sc_y_ext = ymax - ymin
 sc_x_e10 = 2-FIX(LOG10(ABS(sc_x_ext)))  ' calculates the number of digits to display on axis labels
 sc_y_e10 = 2-FIX(LOG10(ABS(sc_y_ext)))  ' calculates the number of digits to display on axis labels
 sc_x_div = sc_x_ext / xjdiv
 sc_y_div = sc_y_ext / yjdiv
 xjinc = gr_x_ext/xjdiv        ' calculate the physical increment for the maJor divisions
 yjinc = gr_y_ext/yjdiv
 xninc = xjinc/xndiv           ' calculate the physical increment for the miNor divisions
 yninc = yjinc/yndiv
 BOX gr_x_min, gr_y_min, gr_x_ext, gr_y_ext, 1, &H303030, &H303030 ' dark grey background
 for x = gr_x_min to gr_x_max+1 step xninc                     ' Minor X Axis tick marks
   LINE x, gr_y_min, x, gr_y_max, 1, &H383838                  ' draw inside the plot box
 next x
 for y = gr_y_min to gr_y_max+1 step yninc                     ' Minor Y Axis tick marks
   LINE gr_x_min, y, gr_x_max, y, 1, &H383838                  ' draw inside the plot box
 next y
 xval = xmin
 for x = gr_x_min to gr_x_max+1 step xjinc                     ' Major X Axis
   xval_disp = STR$(xval,0,sc_x_e10)                           ' Display specified resolution of scaled value
   xval_trnc = val(xval_disp)                                  ' May result in a value of -0.000 (!!)
   IF xval_trnc = 0 THEN                                       ' Strangely, -0.00 equates to zero.
     LINE x, gr_y_min-10, x, gr_y_max, 2, &HA0A0A0             ' Subtly emphasize zero crossing by widening axis line
     xval_disp = STR$(0,0,sc_x_e10)                            ' Avoid showing a "-0.00".  Show 0 to spec. resolution
     TEXT x, gr_y_min-10, xval_disp, CT, 7, 1, RGB(yellow), -1
   ELSE
     LINE x, gr_y_min-10, x, gr_y_max, 1, &H808080
  END IF
  xval = xval + (xmax-xmin)/xjdiv
 next x
 yval = ymin                                                   ' Keep track of scaled values
 for y = gr_y_min to gr_y_max+1 step yjinc                     ' Major Y Axis
   yval_disp = STR$(yval,0,sc_y_e10)                           ' Display specified resolution of scaled value
   yval_trnc = val(yval_disp)                                  ' May result in a value of -0.00 (!!)
   IF yval_trnc = 0 THEN                                       ' Strangely, -0.00 equates to zero.
     LINE gr_x_min-10, y, gr_x_max, y, 2, &HA0A0A0             ' Subtly emphasise zero crossing by widening axis line
     yval_disp = STR$(0,0,sc_y_e10)                            ' Avoid showing a "-0.00".  Show 0 to spec. resolution
     Text gr_x_min-10, y, yval_disp, RM, 7, 1, RGB(yellow), -1
   ELSE
     LINE gr_x_min-10, y, gr_x_max, y, 1, &H808080
   END IF
   yval = yval + (ymax-ymin)/yjdiv
 next y
 ' draw outline around graph area, on top of tick marks
 BOX gr_x_min, gr_y_min, gr_x_ext+2,gr_y_ext+2, 3, &HFFFFFF
END SUB
SUB TitleBox TitleString$   ' draws a graph title centered over the graph area
 BOX tl_x_min, tl_y_min, tl_x_ext, tl_y_ext, 1, &HC0C0C0, &HC0C0C0 ' box for title string
 for x% = tl_x_ctr-1 to tl_x_ctr+1 step 2              ' Make the title Bold
   for y% = tl_y_ctr-1 to tl_y_ctr+1 step 2
     TEXT x%, y%, TitleString$, CM,4, 2, &H000000, -1
   next y%
 next x%
END Sub
SUB LabelAxes xl$, yl$   ' draw axis labels
 TEXT ph_x_min+2, gr_y_ctr,    yl$, LM, 4, 1, RGB(cyan), -1     ' start just off left edge
 TEXT gr_x_ctr,   (gr_y_min+16)/2, xl$, CM, 4, 1, RGB(cyan), -1 ' start just above message area
END SUB
SUB Move Plot_x, Plot_y   ' Moves (without drawing) the virtual pen.  A move must precede the first Plot
 last_sc_x = Plot_x
 last_sc_y = Plot_y
' WaitStatus "Move to "+STR$(Plot_x)+", "+STR$(Plot_y), &H000000
END SUB
FUNCTION Contained (value, l_bound, u_bound) AS INTEGER         ' Range check.  Used in clipping the plot
 IF MIN(l_bound, u_bound) <= value AND value <= MAX(l_bound, u_bound) THEN Contained = 1 ELSE Contained = 0
END FUNCTION
SUB Draw Plot_x, Plot_y, Width, PenColor                        ' Plot with naive clipping.
 LOCAL INTEGER x1,y1,x2,y2, old_contained, new_contained
 x1 = gr_x_min + INT((gr_x_ext * (last_sc_x - sc_x_min) / sc_x_ext))
 y1 = gr_y_min + INT((gr_y_ext * (last_sc_y - sc_y_min) / sc_y_ext))
 IF Contained(x1, gr_x_min, gr_x_max) AND Contained(y1, gr_y_min, gr_y_max) THEN old_contained = 1  else old_contained = 0
 x2 = gr_x_min + INT((gr_x_ext * (Plot_x    - sc_x_min) / sc_x_ext))
 y2 = gr_y_min + INT((gr_y_ext * (Plot_y    - sc_y_min) / sc_y_ext))
 IF Contained(x2, gr_x_min, gr_x_max) AND Contained(y2, gr_y_min, gr_y_max) THEN new_contained = 1  else new_contained = 0
'  PauseStatus "Draw to "+STR$(Plot_x)+", "+STR$(Plot_y)+" ("+STR$(x1)+","+STR$(y1)+") to ("+STR$(x2)+","+STR$(y2)+")", 0
 ' FOR CLIPPING, we must evaluate whether the new or old coordinates are within the plot area.
 ' If both new and old are inside the plot area, go ahead and draw the line.
 IF (old_contained + new_contained) = 2 THEN LINE x1, y1, x2, y2, 1, PenColor  ' both are inside.  Easy peasy!
 ' If old and new are both outside the plot area, don't draw the line at all.
 ' If one is inside and the other is outside (doesn't matter which), don't draw the line at all (for now).
 ' Later, we'll find the point on the edge that is on the line, draw from the inside point to that point.
 last_sc_x = Plot_x : last_sc_y = Plot_y   ' No matter what, update the last scaled x & y.
END SUB
SUB Point Plot_x, Plot_y, Diameter, Color               ' Plot a dot at the scaled coordinates.  Naive clipping.
 LOCAL INTEGER x1, y1, old_contained, new_contained
 x1 = gr_x_min + INT((gr_x_ext * (Plot_x - sc_x_min) / sc_x_ext))
 y1 = gr_y_min + INT((gr_y_ext * (Plot_y - sc_y_min) / sc_y_ext))
 IF Contained(x1,gr_x_min,gr_x_max) AND Contained(y1,gr_y_min,gr_y_max) THEN CIRCLE x1, y1, Diameter, 1, 1, Color, Color
 last_sc_x = Plot_x
 last_sc_y = Plot_y
END SUB
SUB DisplayStatus Message$, Color                         ' Shows a status message at the bottom of the screen.
 BOX ph_x_min, ph_y_min, ph_x_max, 15, 1, &H808080, &H808080 ' Box for status line
 TEXT ph_x_min, ph_y_min, Message$, LB, 1, 1, Color, -1
END SUB
SUB PauseStatus Message$, Color                           ' Shows message, then waits one second
 LOCAL STRING k$
 Timer = 0 : DO WHILE Timer < 1000 : LOOP
END Sub
SUB WaitStatus Message$, Color                            ' Shows message, waits for a keypress
 LOCAL STRING k$
 DisplayStatus Message$+"  Press any key to continue.", Color
 k$ = inkey$ : DO WHILE k$ = "" : k$ = inkey$ : LOOP
END Sub
SUB ClearStatus                                            ' Clears message area
 BOX ph_x_min, ph_y_min, ph_x_max, 15, 1, &H000000, &H000000 ' Box for status line
END SUB
'                                Main Program
'                    Example drawing trigonometric functions
SetPlotParams 11, 16    ' Video mode and color depth.  Values combined inside subroutine
TitleBox STR$(defaultMode)+": Trig Functions incl Sin"+CHR$(253)  ' superscript 2
DrawPlotArea -270.0, 270.0, -2.0, 2.0, 12, 10, 5, 5    ' draw axis tick marks.  Majors cross; minors inside
LabelAxes "Angle "+ CHR$(&HE9) + " (deg)", "Volts"
Move -270, SIN(-270)                                    ' must Move before a Draw command
for theta = -270 to 270 step 10 ' in degrees
 Draw  theta, SIN(theta), 2, RGB(red)
 Point theta, SIN(theta), 2, RGB(red)
next theta
Move -270, COS(-270)
 Draw  theta, COS(theta), 2, RGB(blue)
 Point theta, COS(theta), 2, RGB(blue)
next theta
Move -270, (SIN(-270))^2
for theta = -270 to 270 step 1 ' in degrees
 Draw  theta, (SIN(theta))^2, 2, RGB(green)
'  Point theta, (SIN(theta))^8, 2, RGB(green)
next theta
BOX gr_x_min, gr_y_min, gr_x_ext+2,gr_y_ext+2, 3, &HFFFFFF  ' draw border again to clear up any oopsies'
DisplayStatus "[p] to print, [c] to continue", &H000000
key$ = ""
DO WHILE key$ <> "Q"
 key$ = UCASE$(inkey$)
 SELECT CASE key$
   CASE "C"
     EXIT DO
   CASE "P"  ' Print Screen - saves to .BMP file
     SAVE IMAGE "plotplan"+STR$(defaultMode)+".BMP"
 END SELECT
LOOP
'                        2D color projection of 3D Lissajous
DisplayStatus "Please wait while drawing...", &HFFFF00
TitleBox "2D Projected 3D Lissajous Figure with naive clipping"
DrawPlotArea -2.0, 2.0, -1.0, 1.0, 8, 4, 5, 5    ' draw axis tick marks.  Majors cross; minors inside
FOR theta = 0 to 14400 step .125                  ' ensures thick coverage of the figure
 x_3d = SIN(11.1*theta)    ' calculate 3D lissajous points
 y_3d = SIN(11.125*theta)
 z_3d = COS(11.15*theta)
 x_2d = x_3d - .7*z_3d     ' project them onto a 2D plane
 y_2d = y_3d - .7*z_3d
 IF theta=0 THEN Move x_2d, y_2d ELSE Draw x_2D, y_2d, 2, (127*(1-z_3d) + ((127*(1-y_3d)) << 8) + ((127*(1-x_3d)) << 16))
NEXT theta
DisplayStatus "[p] to print, [q] to quit", &H000000
key$ = ""
 SELECT CASE key$
   CASE "Q"
     EXIT DO
 END SELECT
LOOP
cls
end
panky
Posted: 06:00am 17 Oct 2020
Very nice Steve, been thinking of something like this for a while to graph/plot some battery discharge curves - you have saved me a lot of work!
Thanks,
Doug.
NPHighview
Posted: 06:18am 17 Oct 2020
Hi, Doug - Thanks!
I've also been playing with an oscilloscope version, not yet ready to show.  I'm attempting to do the display as a relatively fixed backdrop of the plot area, with another "live" display plane on top of it.  However, I'm still plowing my way through the examples and documentation, and it's still not behaving for me :-)
Steps for improvement here:
* Use Peter's matrix functions to do a better job with clipping calculations (vector dot products)
* read from a previously-recorded data file (like your battery discharge curves) to generate the plot points.  I don't particularly relish the thought of writing an XML parser for this, so maybe revert to the 1990's "Data Interchange Format" file structure, or even CSV.
* have a "light" mode setting as well as this "dark" mode version.  A "light" mode would look better when inserted into documents, but the dark mode sure looks good on a screen :-)
- Steve
Posted: 09:13am 17 Oct 2020
Looks good.
There's a mode (12 IIRC) which might help with the overlaying of a fixed backdrop.
Posted: 12:34pm 17 Oct 2020
A beautiful example and a beautiful program. Program organization, capitalization of BASIC keywords, variable naming convention, comments--all very craftsmanly done.
There's a lot to learn from here stylistically as well as functionally.
Congratulations.
Paul_L
Posted: 03:03pm 17 Oct 2020
Hmmmmpf!
  Quote  To become familiar with CMM2 and mmBasic, I've written a little plotter package ....
A likely story! This is not a first timer program. Very nice! However, I think I spotted some detail gotchas.
You must be a FORTRAN guy because I see this line
Now, everybody knows that i and j must always be integers, but, you're being redundant. You used INTEGER and all those "%" integer marks. Choose one, either INTEGER or % after each variable.
Then there is this line
DIM FLOAT theta
and then this loop
NEXT theta
where theta has to be a FLOAT because the step is 0.125.
Of course, it would be prettier if you did this
 IF theta=0 THEN
   Move x_2d, y_2d
 ELSE
 ENDIF
The then we see several repetitive loops like this
next theta
which will work but it might or might not run faster if theta were an integer.
And, you forgot that you are a FORTRAN guy. You never used i% or j% anywhere. You could use i% or j% in these DRAW and POINT loops and they might run faster.
However you should not do this
for i%= -270 to 270 step 10
 Draw  i%, SIN(i%), 2, RGB(red)
 Point i%, SIN(i%), 2, RGB(red)
next i%
because the presence of all those "%"s will slow the interpreter down because it has to check to see that it is incrementing an integer for each loop.
It could be written like this
DIM INTEGER i, j
for i= -270 to 270 step 10
 Draw  i, SIN(i), 2, RGB(red)
 Point i, SIN(i), 2, RGB(red)
next i
BUT THIS MUST BE TESTED.
It might just be that the interpreter has to convert the i% to a temporary float before it can execute SIN(i%). This could be the oddball situation where a float could be faster than an integer because of the possible need to convert the i% to a temporary internal float every time the SIN(i%) is encountered.
Peter would be able to answer this, or you could just test it by timing the loops
in both configurations.
Also, at the top of the file we see this
END FUNCTION
I don't think the truncation at zero will work since you reassign LOG10 unconditionally in the next step.
Could it be that this what you intended to do?
IF v <= 0.0 THEN
else
endif
function
END FUNCTION
Interpreters can be very tricky. Sometimes the fastest way winds up being slower. It's all in the details. I got this picky because I started out hand sorting decks of scrambled Hollerith cards containing machine code instructions.
Hint, if you use MMEDIT to write your code it has an excellent automatic indent function which will vividly show the structure of your code. It will catch a lot of screwed up test structures for you.
Paul in NY
Edited 2020-10-18 01:09 by Paul_L
NPHighview
Posted: 04:33pm 17 Oct 2020
Paul and other commentators -
Thanks for the close code inspection!  You're right; this isn't my first rodeo.  But not FORTRAN (bleccch!)  I've written in HP Basic, PL/M, C, C#, C++, PL/SQL, Haskell, F#, Pascal, and a bunch of other languages.  I'm also playing with the wonderful SwissMicros Hewlett-Packard-like DM42 and DM41X calculators.
And you're absolutely right about the LOG10 code; I'm embarassed to say that I missed that late one night and didn't pick it up later in my testing.
You did pick up that I'm not always using MMEdit.  There are some things I just can't live without:
* Global search & replace
* Keyboard shortcuts (Shift-arrow to select, Ctrl-arrow to skip from word to word, etc.)
So I wind up using Atom or Notepad++, then move the SD card to the CMM2 for final checkout.  Tabs get converted to spaces along the way, sometimes inconsistently.
If anyone else finds a bug, I would be very happy to hear about it.
- Steve
Edited 2020-10-18 02:43 by NPHighview
William Leue
Posted: 04:43pm 17 Oct 2020
Looks very nice! It appears that as written, it needs one of the 5.05.06 release candidate firmware versions because of things like OPTION ANGLE DEGREES. It might be good to include that caviat in the top-line comments.
-Bill
NPHighview
Posted: 06:01pm 17 Oct 2020
Thanks, Bill.
The plotter package, per se, doesn't need the OPTION ANGLE, though the Lissajous and Sine plots do use them (and even they really don't need 'em).    I will put some notes up top to that effect.  My intention is to package this as an .inc, minimizing version dependencies as much as I can.
I do use OPTION EXPLICIT, as I'm a big fan of strongly-typed languages (exposes lots of "silent" type-conversion problems).  Haskell  really lit up my brain on that one, especially after decades of C programming.  However, once debugged, I can remove OPTION EXPLICIT with no problem.
I also use OPTION Y_AXIS UP, which does require 5.05.xx, i believe.  I started trying to get a version to work regardless of the Y Axis orientation, but just couldn't wrap my head around all of the issues involved :-)  Peter is working on getting the bitmap capture to work correctly with OPTION_Y_AXIS UP; I had to flip the image to show it, above.
Speaking of Haskell, I'm really intrigued by the existence of mmBasic's EVAL function.  Haskell offers lazy evaluation, map/reduce, currying, tail recursion, and other "contemporary" language features, and the EVAL function just might enable mmBasic to do some of them, at least.
- Steve
Edited 2020-10-18 04:08 by NPHighview
Posted: 06:15pm 17 Oct 2020
  Quote  Peter is working on getting the bitmap capture to work correctly with OPTION_Y_AXIS UP; I had to flip the image to show it, above.
If you download RC4 now it should be fixed. The code you have created is great
Edited 2020-10-18 04:16 by matherp
vegipete
Posted: 07:02pm 17 Oct 2020
Neat program. And more time spent figuring out "How he dunnit?"
Although it does demonstrate that I must get my oscillator mod done.
  Paul_L said  Hmmmmpf!
 IF theta=0 THEN
   Move x_2d, y_2d
 ELSE
 ENDIF
If you are going to 'Hmmmmpf' about this, perhaps a better change would be examine why the "IF" is there in the first place and determine how to remove it:
Move -0.7, -0.7
FOR theta = 0.125 to 14400 step .125                  ' ensures thick coverage of the figure
NEXT theta
NPHighview
Posted: 07:21pm 17 Oct 2020
Wow - comments from Peter and Vegipete!  I'm honored.
Again, this is a wonderful ecosystem and community.  Thank you!  I'm looking forward to the next firmware release.
- Steve
Sasquatch
Posted: 07:43pm 17 Oct 2020
  NPHighview said  To become familiar with CMM2 and mmBasic, I've written a little plotter package that generates scaled 2D plots with axis labeling and (naive) clipping.  Two sample plots get generated by the "Main Program" code after all the subs and functions.  I've commented the code fairly diligently.  Please let me know if this is of any interest.
Very Nice!     This will be very useful. Yes, I am Very Interested!
A couple of things I noticed:
1.  You could use "rotated" text (90 deg) for Y-Axis label.  See "Text" command in manual. This would give even more space on screen for the graph.
2. Would be nice to have a routine that would accept arrays for the X and Y data points and plot them with option to have X axis be the index of the data point.
2. Would be great to have some kind of intelligent "Auto Scale" routine.  This would likely need to parse through the data once (in an array?) to determine Min/Max of data and then choose Min/Max for the graph axis based on some power of 10 and give nice even increments for the scale of the major and minor tics.  I may have some code for this around somewhere but it would take some time to find, or shouldn't be too difficult to think through.
Please take this as constructive suggestions, I think you have done a great job with this and I plan to use it.
-Carl
NPHighview
Posted: 08:24pm 17 Oct 2020
Thanks, Carl!
1. Just found the reference on p. 30 of the CMM2 User Manual 5.05.05 - thanks for the nudge. I agree - very, very desirable.  The firmware version I've got does some really strange things with the different orientations; I'll have to try Peter's most recent.
2. Arrays, or specify a data file to read; either Data Interchange Format or CSV; I'm not going to write an XML parser in mmBasic
3. I'm at least partially there with the auto scale, since the major axis labelers will automatically determine the number of decimals to print based on the dynamic range.  I, too, wrote an autoscaler in HP9800 Basic, the listings for which were on thermal paper that decomposed only, harumph, about 35 years ago :-)  The axis labeler code (calculating a Log10 value for the range ('extent' in my code), then adding one major tic axis increment top & bottom, then truncating, should do the trick.
All criticism welcome!  Many eyes make all bugs shallow - Eric S. Raymond
- Steve
Edited 2020-10-18 07:14 by NPHighview
Sasquatch
Posted: 09:50pm 17 Oct 2020
Seems to be ok on RC3, I doubt this code has changed in a good long while.  Try "CTU" or "CTV" for the alignment$ parameter, also the parameter is a string so needs to be in double quotes or a string variable.
Also the manual under "Text" command has a more complete explanation.
Edited 2020-10-18 07:52 by Sasquatch
-Carl
NPHighview
Posted: 10:44pm 17 Oct 2020
Carl, Peter -
I just loaded RC4.  Some good news, and some bad news:
* Bitmap capture is now "right side up" - thanks!
* Various non-default alignments still show really weird results.  Here's the code snippet for drawing the left-hand axis label:
 TEXT ph_x_min+20,  gr_y_ctr,       yl$, "LMU", 4, 1, RGB(cyan), -1 ' start just off left edge
 TEXT gr_x_ctr,    (gr_y_min+16)/2, xl$, "CM",  4, 1, RGB(cyan), -1 ' start just above message area
END SUB
...and here's the resulting output (the rest of the plot shows up great):
Still seems to me to be an OPTION VERTICAL_AXIS UP issue.
Thanks to you both!  and to Paul in NY, for whom I've now corrected the LOG10 function, and eliminated all unused declarations.
- Steve
Paul_L
Posted: 02:42am 18 Oct 2020
  NPHighview said  You did pick up that I'm not always using MMEdit.  There are some things I just can't live without:
- Steve
Only FORTRAN (not FORTRAN II) guys always use I and J as integer counters. I myself started out with machine language on the 1401 long before FORTRAN showed up.
I usually use NP++ to write my code. Then, after I save the code I leave NP++ running with the file still loaded and switch focus back to the desktop, start MMedit, wait for it to load the file last file it loaded automatically (probably the code I'm working on now), run the format routine, save the program file, close MMedit, and focus back to NP++. NP++ detects that something else has changed the file currently loaded and asks if I want to re-load it. I reply yes please re-load it and it re-loads the now newly formatted file.
This routine,
save
switch focus away from NP++
click start MMedit
format
save
close MMedit
switch focus to NP++
re-load newly formatted file
takes about 5 seconds and saves a lot of heartache when I screw up some structure. Code that should be at the left margin will be indented after un-closed structures!
Paul in NY
Tinine
Posted: 12:03pm 18 Oct 2020
This routine,
save
click start MMedit
format
save
close MMedit
Paul in NY
I am looking at following this procedure.
Are there any more tips/tricks for using MMedit in conjunction with NP++?
Posted: 08:23pm 18 Oct 2020
Paul's method works well.
You can also look at MMEditPlus. Together with the NPP plugins, you can format directly in NPP without having to use MMEdit. (Well, you are using bits of MMEdit behind the scenes)
MMUploader will allow you to drag and drop your code from NPP to the Uploader window for instant uploading. I do use that a lot and I am slowly improving it.
An earlier post suggested that MMEdit is missing the keyboard shortcuts ctr-Arrow and Shift-arrow.
They have been there for many years.
My main use for NPP is to search multiple files. Handy when you are looking through C source code trying to find a particular procedure.
NPHighview
Posted: 06:09am 19 Oct 2020
Thanks to all who have commented, and especially Peter, who have helped me improve the quality of the plotter package.  Based on his recent RC5, I've updated the Y axis labeling to show vertically (though if the firmware is 5.0505 the plotter package still works, just with the Y axis label horizontal).  I've modified the demonstration plots slightly for variey here.  This still uses OPTION Y_AXIS UP, but pretty much all of the other OPTIONS are, well, optional     Hopefully, if this fails at all, it fails gracefully.
Here's another plot sample:
And the current listing (sorry, I've got indents set at 2 spaces):
' plotpkg.bas - HP9800-style plotting on the CMM2
' This should be relatively display mode-independent. YMMV!
OPTION BASE 0         ' my personal practice; not required for plotter package
OPTION EXPLICIT       ' used for development; not required once debugged
DIM FLOAT FirmwareVersion = MM.INFO(version)   ' Test prior to OPTION ANGLE, Y_AXIS
IF FirmwareVersion < 5.0505 THEN CLS : PRINT "Sorry, this software requires firmware 5.0505 or above." : END
OPTION ANGLE DEGREES  ' Used by sample plots; not required for plotter package
OPTION Y_AXIS UP      ' Note upright Bitmap capture requires v.5.0506RC4 and up.
                     ' Vertical orientation of Y axis labels requires v.5.0506
                     ' but will work around with v.5.0505, just horizontally
' Declarations for Plotter package.  Available to, but not required by samples
'   Naming Conventions:
'        ph: Physical   gr: Graph    tl: Title Box   sc: Scaled
'       min: minimum   ctr: center  max: maximum    ext: extent  inc: increment
DIM FLOAT sc_x_min, sc_x_ext
DIM FLOAT sc_y_min, sc_y_ext
DIM INTEGER initial_move = 0  ' A flag that tracks whether a MOVE command preceeded any PLOT command
' Declarations for sample plots - NOT USED in plotter package
DIM STRING key$   ' captures user keypresses
 IF v <= 0.0 THEN LOG10 = -9.99E19 ELSE LOG10 = log(v)/log(10)
END FUNCTION
 LOCAL INTEGER vres%, hres%
 CLS
' Graph dimensions
' Title dimensions
 tl_x_min = gr_x_min
 tl_x_max = gr_x_max
 tl_x_ctr = gr_x_ctr
' Scaled Operations
 last_sc_x = 0
 last_sc_y = 0
END SUB
 sc_x_min = xmin
 sc_y_min = ymin
 yninc = yjinc/yndiv
 next x
 next y
 xval = xmin
   ELSE
  END IF
 next x
   ELSE
   END IF
 next y
END SUB
 LOCAL INTEGER x%, y%
   next y%
 next x%
END Sub
 IF FirmwareVersion > 5.0505 THEN
   TEXT ph_x_min+20, gr_y_ctr, yl$, "CMU", 4, 1, RGB(cyan), -1 ' vertical,  start just off left edge
 ELSE
   TEXT ph_x_min+2, gr_y_ctr, yl$, "LM", 4, 1, RGB(cyan), -1 ' horizontal,  start just off left edge
 END IF
END SUB
 last_sc_x = Plot_x
 last_sc_y = Plot_y
 initial_move = 1        ' set the flag once a move is done
END SUB
END FUNCTION
 IF NOT initial_move then EXIT SUB                         ' requires a move prior to draw
END SUB
 last_sc_x = Plot_x
 last_sc_y = Plot_y
 initial_move = 1      ' This constitutes an initial move, since last_sc_. are set
END SUB
END SUB
 LOCAL STRING k$
END Sub
 LOCAL STRING k$
END Sub
END SUB
SUB PrintScreen Filename$       ' Actually, just saves to .BMP File
 IF FirmwareVersion < 5.0506 THEN
   DisplayStatus "Writing File " + Filename$ + ".  You will need to flip output vertically", &HFFFF00
 ELSE
   DisplayStatus "Writing File " + Filename$ + ".", &HFFFFFF
 END IF
 SAVE IMAGE Filename$
 ClearStatus
END SUB
'                                Main Program
TitleBox "2D Trig Functions"
DrawPlotArea 0, 540, -1.75, 1.75, 12, 6, 5, 5    ' draw axis tick marks.  Majors cross; minors inside
Move 0, SIN(0)                                    ' must Move before a Draw command
for theta = 0 to 540 step 9     ' in degrees; dots on minor axis lines
next theta
Move 0, COS(0)
for theta = 0 to 540 step .5     ' in degrees
 Draw  theta, COS((theta/5)^2), 2, RGB(blue)
 IF theta/9 = INT(theta/9) THEN Point theta, COS((theta/5)^2), 2, RGB(blue)
next theta
Move .25, (50*SIN(7*.25)/.25)
for theta = .25 to 540 step .25  ' in degrees
 IF theta <> 0 THEN Draw  theta, 50*(SIN(7*theta))/theta, 2, RGB(green)
 IF theta/9 = INT(theta/9) THEN Point theta, 50*(SIN(7*theta))/theta, 2, RGB(green)
next theta
DisplayStatus "[p] print, [q] quit, any other key to continue", &H000000
DO
 SELECT CASE UCASE$(inkey$)
   CASE ""  : ' do nothing but loop for a keypress
   CASE "P" : PrintScreen "TrigPlot.BMP" : DisplayStatus "[p] print, [c] continue, [q] quit", &H000000
   CASE "Q" : CLS : END
   CASE ELSE: EXIT DO
 END SELECT
LOOP
 IF theta=0 THEN
   Move x_2d, y_2d
 ELSE
 END IF
NEXT theta
DisplayStatus "[p] to print, any other key to quit", &H000000
DO
   CASE "P" : PrintScreen "Lissajous.BMP" : DisplayStatus "[p] to print, any other key to quit", &H000000
   CASE ELSE: EXIT DO
 END SELECT
LOOP
cls
end
