Local Time 14:28 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: firmware extensions required to support a custom shell
Posted: 11:54am 16 Oct 2020
Apologies, despite my best efforts I've been thinking about this:
1. A mechanism to identify a custom shell program; either an OPTION or a named file in a fixed location, e.g. a file called SHELL.BAS in the root.
2. A program that exits via END or Ctrl-C automatically executes the shell program when it returns to the BASIC command line.
3. An alternative to Ctrl-C, e.g. Ctrl-X which returns to the BASIC command line and does not execute any shell program.
4. An extension to the END keyword that mean exit to BASIC without executing the shell program.
5. An extension to ON ERROR to allow a program to control whether it should exit to BASIC or execute the shell program
  - in the latter case MM.ERRNO and MM.ERRMSG$ would ideally be written to a file in a known location, e.g. a file called ERROR in the root, or somehow passed in on the MM.CMDLINE$ of the shell program.
I don't suppose there is any possibility of this in the future ?
Edited 2020-10-16 22:02 by thwill
Posted: 12:37pm 16 Oct 2020
I assume this is a joke and will treat it as such
Posted: 12:48pm 16 Oct 2020
That would be a "No" then
