Local Time 02:52 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Stop Screen Scrolling
Chopperp
Posted: 08:56am 08 Oct 2020
Is there a way to prevent the CMM2 screen from scrolling upwards if a PRINT @(x,y) data statement goes beyond the bottom of the screen?
I thought I read something about it somewhere, but I can't remember where.
I'm monitoring received data & I think the odd CR/LF comes through & upsets things.
(I probably could trap any CR/LF's before printing)
Brian
ChopperP
PeteCotton
Posted: 04:21pm 08 Oct 2020
Putting a semicolon on the end of the string part might help - it supresses the linefeed for that print statement. However if the Y value is actually off the bottom of the screen I'm not sure it would help.
i.e. PRINT @(x,y) "Sometext";
TweakerRay
Posted: 05:43pm 08 Oct 2020
I have done a tutorial to my chiptune drumsynth...
https://youtu.be/vKMbMjoa0P4
The download to that programm is also in the description of that youtube video.
Hope some enjoy this ;-)
http://tweakerray.bandcamp.com
Chopperp
Posted: 11:25pm 08 Oct 2020
@ PeteCotton Thanks. Will experiment
@ TweakerRay. Nice program but not quite sure how this answers my question.
Brian
ChopperP
Womble
Posted: 11:59am 09 Oct 2020
  Chopperp said  Is there a way to prevent the CMM2 screen from scrolling upwards if a PRINT @(x,y) data statement goes beyond the bottom of the screen?
Brian ...
You could write a wrapper for the PRINT statement to check for screen boundaries.
I did something like that here with my "Glocate" SUB
SUB Glocate row%, col%
LOCAL x% = col%
LOCAL y% = row%
IF x% < 0 OR x% > ( MM.HRES \ MM.INFO(FONTWIDTH) ) THEN      'max character in row
  x% = MM.HRES \ MM.INFO(FONTWIDTH)                          'set to max characters
ENDIF
IF y% < 0 OR y% > ( MM.VRES \ MM.INFO(FONTHEIGHT) ) THEN     'max rows onscreen
  y% = MM.VRES \ MM.INFO(FONTHEIGHT)                         'set to max rows
ENDIF
PRINT @((MM.INFO(FONTWIDTH)*x%),(MM.INFO(FONTHEIGHT)*y%))""; 'position cursor
'where x is the character column, and y is the character row
END SUB
Any checks for stray CR/LF data could be incorporated here too.
Womble
Chopperp
Posted: 11:20am 10 Oct 2020
Thanks for that Womble.
I experimented with some code to check for CR/LF & put this into service this morning into the ISR's of the 2 COM ports for testing. I figured that the CMM2 was fast enough to handle it here.
Two lots of data come in on one channel & one on the other. All 3 get printed (in sequence) to same part of the screen.
Been running all day & so far all OK. No screen scrolling at all. See how it goes.
It took me a while to realise that if the CR is not replaced as well (if not at the end), the remaining part of the message will overwrite the first section & thus not display correctly.
sub Com_Int       'interrupt routine for com port 1
 local x
 Cont_Data$ = input$(113, #1)  'Get Data String. Should be 113 bytes inc LF & CR bytes
 Data_Flag = 1                               'set data flag on Data receive
 for x = 1 to 111                            'first 111 bytes
   if asc(mid$(cont_data$, x, 1)) = 13 then  'check for CR
     mid$(Cont_Data$,x,1) = " "              'replace with a space
   else if asc(mid$(cont_data$, x, 1)) = 10 then 'check for LF
     mid$(Cont_Data$, x,1) = " "                 'replace with a space
   endif
 NEXT x                                          'next chr
 print @(0, 552) time$ "  " left$(Cont_Data$,111) :Print @(0,0)'print to screen
end sub
Brian
ChopperP
