Local Time 14:36 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Sprites colliding with characters of fonts and with pixels
bar1010
Posted: 07:03pm 07 Oct 2020
Color Maximite 2
What is a good way to handle collisions of sprites with things other than other sprites and the edges of the screen?  For example a sprite colliding with a character of a font or with a box shape that has been drawn?
Edited 2020-10-08 05:04 by bar1010
TweakerRay
Posted: 12:00pm 11 Oct 2020
charmove.zip
Hi ! I have not worked with sprtes yet but I am working on a small gametest with collision of chars... maybe this helps you...
in this programm you can move a coursor and if you hit a star (the bait) you will hear a short beep and the baits are reduced -1 :-)
I also made some barriers as # symbols...
right now if you move the coursor and it gets to one of the # symbols it wont go over that...
so I guess you simply do some kind of matrx where you store if the sprite can move there...
I made a array (xygrid) and that stores information if there is a barrier
if there is a barrier the xygrid has the value 1 on the cordinates
when you try to move there the move will be reversed.
for not going over the edges I simply made some restrictions...
if the xcordinate is smaller your border then the move wont go there.
same with ycordinates and so on if the value for x or y is to big for the other border.
(see restrictions in my programm)
So maybe it helps you to do the same with sprites ?
Edited 2020-10-11 22:05 by TweakerRay
http://tweakerray.bandcamp.com
