Local Time 03:06 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : COMMS GOTCHA
Chopperp
Posted: 10:36am 07 Oct 2020
Hi
I spent a considerable amount of time & effort in finding out why one of my HC-12 test links wasn't responding with the correct amount of data.
It was working OK & then sort of stopped sending the full data stream.
I tested & did many things but eventually found the problem.....
DO NOT CLOSE A COM PORT UNTIL THE TX BUFFER HAS SUFFICIENT TIME TO EMPTY.
Delaying the CLOSE #1 command by a second did the trick. I inadvertently had the command immediately after the PRINT #1, command during testing.
Lesson learnt (until next time)
Brian
ChopperP
Posted: 10:39am 07 Oct 2020
You can always use LOF() to see whats remaining in the TX buffer
Saves waiting for too long.
Chopperp
Posted: 10:59am 07 Oct 2020
Thanks for that Jim.
Interesting reading the notes on LOF()
About 120mS of data being cut off at 60mS. Something I never thought of before.
Brian
ChopperP
Posted: 01:45pm 07 Oct 2020
This was changed in Ver 5.05.02 for the Micromite and Micromite Plus:
  Quote  When a serial port is closed MMBasic will now wait for any data in the transmit buffer to be sent before shutting off the port.  Previously the port would have been closed immediately and any characters in the buffer would have been discarded.
Chopperp
Posted: 10:09pm 07 Oct 2020
OK, inadvertently loaded 5.05.01 when swapping 28 pinners etc.
Will try '.02.
My apologies...
Thanks Geoff
ChopperP
