Local Time 14:46 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Basic on a dip ....
hitsware2
Posted: 02:52am 07 Oct 2020
Anyone try one of these ?
my site
Posted: 07:13am 07 Oct 2020
On their web page they claim it is a compiler basic.
The add says pre-loaded with Basic.
Not sure what to think.
Anyway, I generally have not enough IO pins on a 28pin MX170, so there may be not enough IO on this one also.
hitsware2
Posted: 04:11pm 07 Oct 2020
Cannot pre-load compiler basic ?
edit:
Maybe the ' compiler ' is on the chip ?
Edited 2020-10-08 02:21 by hitsware2
my site
hitsware2
Posted: 06:02pm 07 Oct 2020
Per Coridium / :
The uChip has the BASIC firmware installed.  Firmware includes library routines, like floating point operations, string operations, integer divide, printf and others.  The freely downloaded compiler resides on a PC and outputs hex files that are ARM instructions or calls to those library routines.
From time to time we have offered ports of the compiler to Linux systems, but most people use VM.
Recently we ported the TclTerm utility to the Raspberry Pi which allows communication to a BASIC program on the uChip (our blog entry)
https://www.coridium.us/coridium/blog/raspberrypi-interface
While it would be possible to port all the tools to the RasPi, in our opinion it is a bit slow and has primitive text editors, and we would recommend using a PC to develop your BASIC program.
Bruce Eisenhard
Coridium Corp
www.coridium.us
my site
