Forum Index : Microcontroller and PC projects : 16,000 BBC Sound effects
bigmik![]() Guru Joined: 20/06/2011 Location: AustraliaPosts: 2984 |
G’day All, The BBC has allowed 16,000 sound effects to be used for non-commercial use. See this link, read the terms and conditions before you use them to ensure you fit their conditions. BBC Sound Effects Hope this is useful. Regards, MICK Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
| elk1984 Senior Member Joined: 11/07/2020 Location: United KingdomPosts: 232 |
Great spot - thanks! On a related note, what do people make of Youtube's T&Cs on their audio library? https://studio.youtube.com/channel/UCuP3DHFYpfYocnEVcsevx0g/music Music from this library is intended solely for use by you in videos and other content that you create. (emphasis mine). Is it a reasonable interpretation to say this allows use providing the source is attributed and the music is embedded in the program in than stored as a file that can be copied (may not be possible TBH) ? |
| MustardMan Senior Member Joined: 30/08/2019 Location: AustraliaPosts: 175 |
@bigmik Looks good, but to get an effect you have to go to the site and download it from the site. Are you aware if there is a single or multi-part file (eg: ZIP, RAR) that contains the lot, and where one would find it? Cheers, |
