Local Time 14:54 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Size of sprite / framebuffer
elk1984
Posted: 04:47pm 27 Sep 2020
At risk of someone pointing me straight to the manual (I have looked and checked in Peter's excellent Graphics Programming on the Colour Maximite 2) - is there a way to get the size of a sprite, loaded image or framebuffer.
The use case is I'd like to load a bitmap bounded by a box.  Of course I do know the size of the bitmap I'm loading, but if there was a way to get it from the file I'd prefer not to put hardcoded values in my program.
elk1984
Posted: 05:12pm 27 Sep 2020
You are asking three different things. For sprite use the SPRITE function for framebuffer use MM.INFO. For a BMP file you are going to need to read the file header and decode it.-
elk1984
Posted: 06:13pm 27 Sep 2020
  matherp said  You are asking three different things. For sprite use the SPRITE function for framebuffer use MM.INFO. For a BMP file you are going to need to read the file header and decode it.-
Thanks - the mixing up probably reflects my head  .  What I'm trying to do is load a graphic into a sprite to put on screen in a bounded box.  If I use SPRITE LOADPNG, is there a way once it is loaded to access the height and width?
Posted: 09:33pm 27 Sep 2020
These SUbs are from my FileManager program.
They give the vital stats for image files.
sub jpgInfo f$, onDisk AS INTEGER, iWdth AS INTEGER, iHt AS INTEGER, info$
 LOCAL INTEGER block
 LOCAL x$
 onDisk = MM.INFO(filesize f$)
 info$ = ""
 OPEN f$ FOR INPUT AS #2
 DO
   block = ASC(INPUT$(1,#2)) ' flag for start of block
   IF block = 255 THEN
     block = ASC(INPUT$(1,#2)) ' block type
     IF block = &hC0 THEN
       x$ = INPUT$(3,#2)
       iHt = ASC(INPUT$(1,#2))*256 + ASC(INPUT$(1,#2))
       iWdth = ASC(INPUT$(1,#2))*256 + ASC(INPUT$(1,#2))
       EXIT DO
     elseif block = &hC2 THEN
       info$ = "Progressive"
       x$ = INPUT$(3,#2)
       exit do
     ENDIF
   ENDIF
 LOOP
 CLOSE #2
END SUB
sub bmpInfo f$, onDisk AS INTEGER, iWdth AS INTEGER, iHt AS INTEGER, info$
 LOCAL x$
 x$ = INPUT$(18,#2) ' skip this
 iWdth = ASC(INPUT$(1,#2))+ASC(INPUT$(1,#2))*256
 iWdth = iWdth +ASC(INPUT$(1,#2))*2^16+ASC(INPUT$(1,#2))*2^24
 iHt = ASC(INPUT$(1,#2))+ASC(INPUT$(1,#2))*256
 iHt = iHt +ASC(INPUT$(1,#2))*2^16+ASC(INPUT$(1,#2))*2^24
 x$ = INPUT$(2,#2) ' colour planes - not used
 info$ = str$(ASC(INPUT$(1,#2))+ASC(INPUT$(1,#2))*256)+" bit"
 CLOSE #2
END SUB
sub gifInfo f$, onDisk AS INTEGER, iWdth AS INTEGER, iHt AS INTEGER, info$
 LOCAL x$, iBits as integer
 x$ = INPUT$(6,#2) ' skip this GIF89a
 x$ = INPUT$(1,#2) ' colour table start and bits
 iBits = (asc(x$) and &b00000111) + 1
 'if (asc(x$) and &b10000000) then iBits = 0 - iBits ' indicate animated image
 CLOSE #2
 info$ = str$(iBits)+" bit"
END SUB
sub pngInfo f$, onDisk AS INTEGER, iWdth AS INTEGER, iHt AS INTEGER, info$
 ' data from https://en.wikipedia.org/wiki/Portable_Network_Graphics
 x$ = INPUT$(12,#2)
 x$ = INPUT$(4,#2) ' should be IHDR
 iWdth = ASC(INPUT$(1,#2))*2^24 + ASC(INPUT$(1,#2))*2^16
 iWdth = iWdth +ASC(INPUT$(1,#2))*256 + ASC(INPUT$(1,#2))
 iHt = ASC(INPUT$(1,#2))*2^24 + ASC(INPUT$(1,#2))*2^16
 iHt = iHt +ASC(INPUT$(1,#2))*256 + ASC(INPUT$(1,#2))
 iBits = ASC(INPUT$(1,#2)) ' colour bits/pixel
 select case ASC(INPUT$(1,#2)) ' colour type
   case 0
     info$ = str$(iBits)+" bit Grayscale"
   case 2
     info$ = str$(iBits*3)+" bit Truecolour"
   case 3
     info$ = str$(iBits)+" bit Palettised"
   case 4
     info$ = str$(iBits*2)+" bit Grayscale+Alpha"
   case 6
     info$ = str$(iBits*4)+" bit RGBA"
   case else
     info$ = str$(iBits)+" bit/pixel"
 end select
 CLOSE #2
END SUB
Given the file name, they return sizes plus other info.
elk1984
Posted: 07:18am 28 Sep 2020
  TassyJim said  These SUbs are from my FileManager program.
 LOCAL INTEGER block
 LOCAL x$
 info$ = ""
 DO
   IF block = 255 THEN
       x$ = INPUT$(3,#2)
       EXIT DO
       x$ = INPUT$(3,#2)
       exit do
     ENDIF
   ENDIF
 LOOP
 CLOSE #2
END SUB
 LOCAL x$
 CLOSE #2
END SUB
 CLOSE #2
END SUB
 x$ = INPUT$(12,#2)
   case 0
   case 2
   case 3
   case 4
   case 6
   case else
 end select
 CLOSE #2
END SUB
That's fantastic - thanks TassyJim
elk1984
Posted: 06:07pm 28 Sep 2020
Thanks for the inspiration Jim.  Using your code as a basis, I've reworked as an exercise in improving my knowledge of file handling, arrays etc.
The program needs 4 images (test.bmp, test.gif, test.jpg and test.png) in the same directory as the basic file.
image-info.zip
Any review comments welcome, especially that would help make this standalone and reusable for others.
Edited 2020-09-29 04:15 by elk1984
