Local Time 15:02 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: Demystifying Mode 1 Colours
Womble
Posted: 02:18am 24 Sep 2020
I have read the manual, but am so used to the old GWBASIC/QBASIC color numbers that I was getting rather confused.
Wombles are easily confused
In order to demystify this for a numpty like me I wrote this little program.
Mode1COLOURS.zip
' Mode1COLOURS.BAS
' Demystifying the Integer Values and Red Green Blue values for RGB() mode1
' Womble 24SEPT2020
MODE 1,8
CLS
OPEN "Mode1COLOURS.TXT" FOR OUTPUT AS #1   'Open a text file, Output a heading
PRINT #1,"---------------------------------------------------------------------------"
PRINT #1," Mode1COLOURS.BAS"
PRINT #1," Demystifying the Integer Values and Red Green Blue values for RGB() mode1"
PRINT #1," Womble 24SEPT2020"
COLOUR RGB(WHITE) : PRINT #1,"White?",
ColourValueOutput (RGB(white))
COLOUR RGB(WHITE) : PRINT #1,"Black?",
ColourValueOutput (RGB(black))
COLOUR RGB(WHITE) : PRINT #1,"Blue?",
ColourValueOutput (RGB(blue))
COLOUR RGB(WHITE) : PRINT #1,"Green?",
ColourValueOutput (RGB(green))
COLOUR RGB(WHITE) : PRINT #1,"Cyan?",
ColourValueOutput (RGB(cyan))
COLOUR RGB(WHITE) : PRINT #1,"Red?",
ColourValueOutput (RGB(red))
COLOUR RGB(WHITE) : PRINT #1,"Magenta?",
ColourValueOutput (RGB(magenta))
COLOUR RGB(WHITE) : PRINT #1,"Yellow?",
ColourValueOutput (RGB(yellow))
COLOUR RGB(WHITE) : PRINT #1,"Brown?",
ColourValueOutput (RGB(brown))
COLOUR RGB(WHITE) : PRINT #1,"Grey?",
ColourValueOutput (RGB(gray))
CLOSE #1                              'Close the file
'Display the colours onscreen
COLOUR RGB(WHITE) : PRINT "White?",
ColourValuePrint (RGB(white))
COLOUR RGB(WHITE) : PRINT "Black?",
ColourValuePrint (RGB(black))
COLOUR RGB(WHITE) : PRINT "Blue?",
ColourValuePrint (RGB(blue))
COLOUR RGB(WHITE) : PRINT "Green?",
ColourValuePrint (RGB(green))
COLOUR RGB(WHITE) : PRINT "Cyan?",
ColourValuePrint (RGB(cyan))
COLOUR RGB(WHITE) : PRINT "Red?",
ColourValuePrint (RGB(red))
COLOUR RGB(WHITE) : PRINT "Magenta?",
ColourValuePrint (RGB(magenta))
COLOUR RGB(WHITE) : PRINT "Yellow?",
ColourValuePrint (RGB(yellow))
COLOUR RGB(WHITE) : PRINT "Brown?",
ColourValuePrint (RGB(brown))
COLOUR RGB(WHITE) : PRINT "Grey?",
ColourValuePrint (RGB(gray))
'Pause until ESC is pressed
DO : LOOP UNTIL INKEY$=CHR$(27)
END
'Output the colour information to a file
SUB ColourValueOutput pcol%
 'Parameter pcol% is the integer representation of the RGB() value
 LOCAL N$ = HEX$(pcol%)                'Convert to Hexadecimal String
                                       'only 24 bits are colour info
 LOCAL TN$ = "&H"+MID$(N$,2,2)         'Extract Red Component (top 8bits)
 LOCAL MN$ = "&H"+MID$(N$,4,2)         'Extract Green Component (middle 8bits)
 LOCAL BN$ = "&H"+RIGHT$(N$,2)         'Extract Blue Component (bottom 8bits)
 PRINT #1,"decimal";pcol%              'Output the value in decimal to a file
 PRINT #1,"Red",VAL(TN$),"Green",VAL(MN$),"Blue",VAL(BN$)  'Output each 8bit value in decimal
 PRINT #1,"Red",TN$,"Green",MN$,"Blue",BN$  'Output each 8bit value in hexadecimal
 PRINT #1,"-----------------------------------" 'print a separating line
END SUB
'Output the colour information to the screen
SUB ColourValuePrint pcol%
 COLOUR RGB(White)                  'Text Heading Colour
 PRINT "decimal";pcol%              'print the value in decimal
 PRINT "Red",VAL(TN$),"Green",VAL(MN$),"Blue",VAL(BN$)  'print each 8bit value in decimal
 COLOUR pcol%                       'Set Output to this colour
 PRINT "Red",TN$,"Green",MN$,"Blue",BN$  'print each 8bit value in hexadecimal
 PRINT "--------------------------------" 'print a separating line
END SUB
It writes a file "Mode1COLOURS.TXT" on to the SD card, and displays the results onscreen (press ESC to exit) and shows the RGB(r,g,b) values for the predefined colour shortcuts.
It also shows how to set the foregraound colours for PRINT statements.
I did not bother with background colours, the syntax is the same (from the manual):
COLOUR fore [, back]
or
COLOR fore [, back]
Sets the default colour for commands (PRINT, etc) that display on the on the VGA monitor. 'fore' is the foreground colour, 'back' is the background colour. The background is optional and if not specified will default to black.
eg. COLOUR RGB(Yellow),RGB(Red)  sets foreground to Yellow, background to Red using the shortcut form (not case sensitive).
This is equivalent to COLOR RGB(255,255,0),RGB(255,0,0)
Mode1COLOURS.BAS
Womble 24SEPT2020
White? decimal 268435455
Red 255 Green 255 Blue 255
Red &HFF Green &HFF Blue &HFF
Black? decimal 0
Red 0 Green 0 Blue 0
Red &H Green &H Blue &H0
Blue? decimal 251658495
Red 0 Green 0 Blue 255
Red &H00 Green &H00 Blue &HFF
Green? decimal 251723520
Red 0 Green 255 Blue 0
Red &H00 Green &HFF Blue &H00
Cyan? decimal 251723775
Red 0 Green 255 Blue 255
Red &H00 Green &HFF Blue &HFF
Red? decimal 268369920
Red 255 Green 0 Blue 0
Red &HFF Green &H00 Blue &H00
Magenta? decimal 268370112
Red 255 Green 0 Blue 192
Red &HFF Green &H00 Blue &HC0
Yellow? decimal 268435200
Red 255 Green 255 Blue 0
Red &HFF Green &HFF Blue &H00
Brown? decimal 268402688
Red 255 Green 128 Blue 0
Red &HFF Green &H80 Blue &H00
Grey? decimal 255868992
Red 64 Green 64 Blue 64
Red &H40 Green &H40 Blue &H40
I am posting this here in case it helps any new CMM2 users.
Womble
Posted: 09:11pm 24 Sep 2020
Ok ... more hacking about to replicate old dialects of Basic (Gw, Q, etc.)
GwBasicCOLOURS.zip
' GwBasicCOLOURS.BAS
' Recreating the GwBasic/QBasic COLOR and LOCATE commands for the CMM2
' cycles through the CMM2 modes in 8bit colour and shows how to determine test screen size
' syntax:
' Gcolour foreground%, background%
' Glocate screenrow%, column%
' Womble 24SEPT2020
'Set array option base to index from 0
OPTION BASE 0
'clear the screen to avoid unwanted scrolling from the CMM2 user interace
CLS
'Constants used to hold RGB values
'Tweak these RGB values to adjust the shades displayed
CONST Gblack%   = RGB(0,0,0)
CONST Gblue%    = RGB(0,0,128)
CONST Ggreen%   = RGB(0,179,0)
CONST Gcyan%    = RGB(0,148,148)
CONST Gred%   = RGB(128,0,0)
CONST Gmagenta%   = RGB(128,0,128)
CONST Gbrown%   = RGB(128,128,0)
CONST Ggray%    = RGB(187,187,187)
CONST Gcharcoal%  = RGB(85,85,85)
CONST Gbblue%   = RGB(85,85,255)
CONST Gbgreen%    = RGB(85,255,85)
CONST Gbcyan%   = RGB(85,255,255)
CONST Gorange%    = RGB(255,85,64)
CONST Gpink%    = RGB(255,64,255)
CONST Gyellow%    = RGB(255,255,0)
CONST Gwhite%   = RGB(255,255,255)
DIM Gcolour%(15)        'Array of RGB values, index is GwBasic color number
'Load the RGB values from the constants into the array
Gcolour%(0) = Gblack%
Gcolour%(1) = Gblue%
Gcolour%(2) = Ggreen%
Gcolour%(3) = Gcyan%
Gcolour%(4) = Gred%
Gcolour%(5) = Gmagenta%
Gcolour%(6) = Gbrown%
Gcolour%(7) = Ggray%
Gcolour%(8) = Gcharcoal%
Gcolour%(9) = Gbblue%
Gcolour%(10) = Gbgreen%
Gcolour%(11) = Gbcyan%
Gcolour%(12) = Gorange%
Gcolour%(13) = Gpink%
Gcolour%(14) = Gyellow%
Gcolour%(15) = Gwhite%
'Test the locate finction and print characters at each corner of screen
Glocate 49,0
print "X";
Glocate 49,99
print "X"
Glocate 0,99
print "X"
Glocate 0,0
print "Mode 1,8 "+STR$(MM.INFO(FONTWIDTH))+"x"+STR$(MM.INFO(FONTHEIGHT))+" font : Hit Esc to Start"
do : loop until inkey$=chr$(27)
'try different modes
for m% = 1 to 12
  mode m%,8
  cls
  Gcolor 15,0                                     'Default Colours
  Glocate ((MM.VRES \ MM.INFO(FONTHEIGHT))-2),1   'Penultimate row
  PRINT "Font "+STR$(MM.INFO(FONTWIDTH))+"x"+STR$(MM.INFO(FONTHEIGHT)),
  PRINT "= Rows "+STR$(MM.VRES \ MM.INFO(FONTHEIGHT))+" Cols "+STR$(MM.hRES \ MM.INFO(FONTWIDTH))
  Glocate ((MM.VRES \ MM.INFO(FONTHEIGHT))-1),1   'Bottom, Left of screen
  PRINT "Mode "+STR$(m%)+".8 "+"Hit ESC to continue";
  for f = 0 to 15
    for b = 0 to 15
      Gcolor f,b
      Glocate f,b
      print "#"
    next b
  next f
next m%
'reset screen mode and exit
mode 1,8
end
SUB Gcolor Gfore%, Gback%
 LOCAL Gf% = Gfore%
 LOCAL Gb% = Gback%
 IF Gf% > 15 OR Gf% < 0 THEN
   Gf% = 15  'default to High Intensity White foreground
 ENDIF
 IF Gb% > 15 OR Gb% < 0 THEN
   Gb% = 0   'default to Black background
 ENDIF
 COLOUR Gcolour%( Gf% ),Gcolour%( Gb% )   'set the colours
END SUB
SUB Glocate row%, col%
 LOCAL x% = col%
 LOCAL y% = row%
 IF x% < 0 OR x% > ( MM.HRES \ MM.INFO(FONTWIDTH) ) THEN      'max character in row
   x% = MM.HRES \ MM.INFO(FONTWIDTH)                          'set to max characters
 ENDIF
 IF y% < 0 OR y% > ( MM.VRES \ MM.INFO(FONTHEIGHT) ) THEN     'max rows onscreen
   y% = MM.VRES \ MM.INFO(FONTHEIGHT)                         'set to max rows
 ENDIF
 PRINT @((MM.INFO(FONTWIDTH)*x%),(MM.INFO(FONTHEIGHT)*y%))""; 'position cursor
 'where x is the character column, and y is the character row
 'https://www.thebackshed.com/forum/ViewTopic.php?TID=12778&PID=155313#155313#155313
END SUB
Its a crude hack but I hope this is helpful to someone
Tested on Firmware V5.05.06b14 both headless (TerraTerm & Windows Camera),
and with a 4:3 VGA screen and keyboard.
Edited 2020-09-25 07:14 by Womble
