Local Time 15:02 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: WAV music + WAV sound effects?
jaholmes
Posted: 10:14pm 23 Sep 2020
(CMM2 noob alert)
Is there a straightforward way to play non-MOD (e.g. WAV) background music and still use WAV sound effects?  User manual and my own experimentation suggest not, but I do miss things.
Wrapping a WAV in a MOD seems doable in theory (and hilariously hacky), though I wouldn't be surprised to learn that it came with memory and/or performance issues.
Best,
Aaron
vegipete
Posted: 10:23pm 23 Sep 2020
Wrapping a WAV in a MOD works very effectively.
Simultaneous separate WAVs isn't possible. However, if you copy a WAV into an array, you can have 1 of the 2 DACs play this array. Look at Martin Scragg's Max-E-Man game to see how he pulled this off.
jaholmes
Posted: 10:41pm 23 Sep 2020
  vegipete said  (snip) if you copy a WAV into an array, you can have 1 of the 2 DACs play this array. Look at Martin Scragg's Max-E-Man game to see how he pulled this off.
Ah!  That's excellent.  Thank you.  The code even manages to be straightforward.  I'll give that a shot.
Best,
Aaron
hitsware2
Posted: 11:36pm 23 Sep 2020
  vegipete said  Wrapping a WAV in a MOD works very effectively.
Is there a way to open a mod file in a text editor ?
my site
vegipete
Posted: 01:05am 24 Sep 2020
No, a MOD file is binary. You need a 'MOD tracker" program of some sort.
hitsware2
Posted: 03:39am 24 Sep 2020
How about a .wav file ?
Someways ( long ago ( with an Amiga ) )
it would play files derived mathematically .
Like a graph .
my site
vegipete
Posted: 07:20am 24 Sep 2020
You can put a waveform into an array and feed it to DAC. Each array element should be numbers in the range 0-4095 to suit the 12-bit DACs.
Here is a silly demo:
' DAC Demo Program
' create a waveform in an array and send it to a DAC for sound playback.
wave_length = 31415
dim integer wave(wave_length)
math set 2047, wave()   ' initialize array to mid-voltage
' fill array with a silly waveform
' use a sin wave as the base, shift the frequency around and fade out at the end
for i = 0 to wave_length
 fade = 1
 if i > wave_length * 0.9 then fade = 10 * (wave_length - i) / wave_length
 wave(i) = 2047 + 2000 * fade * sin(i/(4 + sin(i/3141)))
next i
' play the waveform. use interrupt to play only once
done = 0
dac start 10000,wave(),,DAC_INT
done = 0  ' Why this line? Seems to be an immediate interrupt? Mysterious.
do : loop until done   ' wait for sound to end
end
sub DAC_INT
 done = 1
end sub
I do not understand why line 20 is required. Comments?
Posted: 07:57am 24 Sep 2020
  Quote  done = 0  ' Why this line? Seems to be an immediate interrupt? Mysterious.
Bug - fixed in V5.05.06b14 - I hope
