Local Time 03:33 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : cmm2: error with longish static+sub/function names
epsilon
Posted: 04:32pm 23 Sep 2020
Hi all,
I'm running into an error when using statics with longish names.
I have reduced the issue I'm seeing to the following short program:
'TRACE ON 'To show that problem occurs after n loops
SUB foobarsubrout
 STATIC thisIsAveryLongVName%
END SUB
DO
 foobarsubrout
LOOP
When running this program I eventually get the following error:
Error in line 4: Not enough variable memory
The error only shows up after a number of passes through the DO LOOP as can be seen when you enable tracing.
If I use shorter variable names, the issue disappears.
Any idea what's wrong here?
I'm guessing that the static variable name gets concatenated with the subroutine's name. The sum of the two is 33, which is a bit suspicious. Possibly some boundary condition isn't handled properly in FW?
FW version is 5.05.05.
/Epsilon.
Epsilon CMM2 projects
Posted: 05:19pm 23 Sep 2020
Interesting. Without the "e" on thisIsAveryLongVName% it doesn't fall over--with it, it does.
Posted: 05:23pm 23 Sep 2020
Passed it on to Geoff as is is a generic MMBasic issue - same result on the Micromite
Posted: 09:43pm 23 Sep 2020
The sub name gets appended to the static variable name to create a unique name.
This has to be a maximum of 32 characters.
From the manual under COMMANDS/STATIC
  Quote  This command uses exactly the same syntax as DIM. The only difference is
that the length of the variable name created by STATIC and the length of the
subroutine or function name added together cannot exceed 32 characters.
But I think it could/should be added to the earlier section on page 21 as well.
edit: A 'name too long' error message would help.
Edited 2020-09-24 07:54 by TassyJim
epsilon
Posted: 09:42am 24 Sep 2020
Thanks. That makes sense. Sorry I missed it in the User Guide.
It is a bit strange though that the condition goes unnoticed for a while and then results in a 'Not enough variable memory' error.
If I add one character to either the sub or the static, it does get flagged right away as a 'Variable name too long error'.
Then again, I don't think it has to be MMBasic's job to prevent me from shooting myself in the foot at every corner
Posted: 09:47am 24 Sep 2020
  Quote  It is a bit strange though that the condition goes unnoticed for a while and then results in a 'Not enough variable memory' error.
This is because the name match fails and each time the subroutine is called creates a new variable until the variable space is full. The new version of the firmware will give an appropriate error the first time you call the function
Edited 2020-09-24 19:49 by matherp
