Local Time 15:02 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2 Not Playing Audio Files
JohnD
Posted: 03:33am 23 Sep 2020
JohnD
Posted: 04:03am 23 Sep 2020
I guess that I'll get better at this!
I have a colour maximite 2 running MMBasic Ver 5.05.05. I have a manual for MMBasic Ver 5.05.04. I'm following this manual. In the direct mode the following command strings work:
Play tone 100,200,200
Play wav "basin street blues"
Play wav "" to play all wav files on the SD card
Play modfile "T1"
I have a separately powered desktop stereo speaker system that works well when the commands are made in the direct mode but there is no sound when the commands are made through a single line Basic programme.
When I write a single line basic programme for each of these, the screen shows run a blank line and then the > cursor on the next line.
If I try to play a file with a name that does not exist, the CMM2 reports "Error in line 1: Could not find the file.
What am I doing wrong?
Posted: 04:12am 23 Sep 2020
Perhaps your program is ending before it has time to play the sounds.
Try
DO:LOOP until inkey$ <> ""
before the end
JohnD
Posted: 08:36am 23 Sep 2020
That Fixed it. I didn't think of that. I expected it to work as if was called in the immediate mode. I'll have to write longer programmes. Many thanks.
