Local Time 15:02 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Questions about MMBasic.c
gevik
Posted: 08:51am 21 Sep 2020
I was reading through the MMBasic.c file and would like to know a little bit about the history of how the parser/interpreter came to be. I read "The Maximite Story" and I understand that it was written from ground up inspired from bwBasic.
I would like to know if there was/is a particular reason why a parser generator like yacc/lexx or some modern ones line ANTLR is/was not used.
Thank you.
Posted: 11:07am 21 Sep 2020
Well firstly yacc and lex (only one x) are used to create compilers and this is an interpreter.  I'm not sure about ANTLR but MMBasic was designed to run on microcontrollers with limited memory and I did not want to load it up with needless layers of code.
Essentially a complex layer of tools was not required.  BASIC is quite simple, there is a command with a number of arguments.  Each command does its own thing, no complex pasing required.  Essentially the development started by constructing a simple mechanism for recognising commands and running the associated code.  From then on I just added command after command until it was finished.
Decoding expressions is something else.  In MMBasic this is a recursive algorithm which was not based on any academic principals but was developed by me over a number of long days.  This was the most complex and difficult part and amazingly, even though it was written many years ago, has had no bugs nor need for improvement.
Posted: 01:46pm 21 Sep 2020
Just a note: yacc/lex are fine for interpreters.
(And they'll do recursive expressions etc, of course.)
However, as MMBasic has mutated (especially on CMM2) I wouldn't fancy writing a grammar for it now!
Edited 2020-09-21 23:48 by JohnS
Pilot352
Posted: 03:59pm 22 Sep 2020
  Quote  ...From then on I just added command after command until it was finished.
It's finished?
