Local Time 15:02 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Keeping the cursor flashing
Herry
Posted: 08:22pm 20 Sep 2020
Today's inane question: In my program, when a user is building up an entry screen I want the > cursor to keep flashing at the entry point (although that part of the program is in a loop). The loop has the effect of silencing the cursor. I'd like to overcome that in the entry routine.
Senior?!  Whatever it says, I'm a complete and utter beginner...
Herry
Posted: 08:35pm 20 Sep 2020
I should add that I can emulate the cursor at the insertion point with CHRS(62) alternating with CHR$(32) but if there's an easier way I'd like to avoid that
Posted: 10:09pm 20 Sep 2020
The cursor is the underline, not the ">" which is the prompt and never flashes.
If you are happy with the underline flashing and are able to use INPUT to retrieve your responses, this will do the job:
  Quote  CLS
PRINT @(200,100)"";
INPUT "Answer >",a$
Note the comma after the prompt string to suppress the question mark.
Herry
Posted: 10:53pm 20 Sep 2020
Thanks Jim
You must be on permanent duty!
My program has a much more complicated operation. I set up an input box of a fixed length using String$(x,46) and finishing with CHR$(222). In do loop I use inkey$ to pick up individual characters and build the string and also allow for prevention of overflow as well as intercepting backspace and signalling end of input string using Chr$(13). I'm working on the optimum pause settings to prevent 'keybounce'. I now alternate the 'next' chr$(46) with Chr$(32) to give a flashing cursor at the next character entry point. I'm 'porting' the functions in a large business system I wrote years ago and used for years under DOS (remember that?) and QuickBasic. So my problem is sometimes subtle differences in the operation of CMM2 commands as well as not so subtle aging. Maybe I'll post my code when tidied up to just to give you experts some mirth in this serious world and tempt posters to tear it apart!
Posted: 11:08pm 20 Sep 2020
  Herry said   . . . Maybe I'll post my code when tidied up
If you are doing text boxes and other DOS windows-type things, I'd certainly like to see that code tidy or not.
Herry
Posted: 11:31pm 20 Sep 2020
You asked for it! Here's my old QuickBasic standard subroutine for string input, with allowance for ENTER (end of string) and Backspace.  This is old code and not what I'm doing now as a port from it. Spaghetti I know, but a busy office ran faultlessly on it for years.
800 PLAY O2$: EN$ = "": Color 11, 0: Print "ENTER "; PR$; " ? ";: RO = CSRLIN: CO = POS(0): Print String$(LT, 46); Chr$(222);: LOCATE RO, CO
802 LOCATE , , 1: EK$ = INKEY$: If EK$ = "" Or EK$ = Chr$(9) Then GoTo 802
803 If EK$ <> Chr$(8) Then GoTo 804 Else If POS(0) < CO + 1 Then GoTo 802 Else EN$ = Left$(EN$, Len(EN$) - 1): LOCATE RO, CO: Print EN$ + "." + Chr$(29);: GoTo 802
804 If EK$ = Chr$(13) Then GoTo 805 Else Color 14, 0: Print EK$;: EN$ = EN$ + EK$: GoTo 802
805 Print: If Len(EN$) > LT Then GoSub 508: Print: GoTo 800 Else PR$ = "": EK$ = "": Return
No suggestions please folks(!) New environment now. (all my current business programs have been written under Vb6)
flip
Posted: 11:54pm 20 Sep 2020
I posted a simple MULTI-TASKing program (using MM for DOS) 3 years ago (how time flies) back in https://www.thebackshed.com/forum/forum_posts.asp?TID=9851&PN=49
It's just a demo and very rough and slow...you can tab between windows, type text in them and press Function keys along bottom of screen to start scroller...have since made improvements but no means ready for posting...
Pressing 'Insert' key toggles between OVR and INS modes - which can be seen as different cursors (underline and block)
regards Phil
Posted: 12:17am 21 Sep 2020
  Herry said  You asked for it!  . . . No suggestions please folks(!)
Two-character variable names, heaven help us. (But no suggestions implied.)
Thanks.
Posted: 12:20am 21 Sep 2020
Flip--thanks very much. DOS MMBasic is what I'm looking at for starters. If you have updates to that code, can you post them in the thread you linked, however rough?
Paul_L
Posted: 12:29am 21 Sep 2020
@Herry >> Considering that your code was written before BASIC acquired better conditional test commands and looping structures, I really like it. It's probably about as fast as it can be. The short variable names speed up BASIC's search of the table of variables and they compress the load space for the program. It's probably pretty bullet proof. It's just a little hard for humans to read.
Polacks like me are not really part of the human race and it's been working for years, so I don't mind it.
Paul in NY
Posted: 12:51am 21 Sep 2020
This is one I prepared earlier:
 ' text input routines
 ' TassyJim November 2019
 option console serial ' to stop messing up the display
 const FALSE = 0
 const TRUE = not false
 dim n$(10)
 dim integer tHt = MM.INFO(FONTHEIGHT), tWth = MM.INFO(FONTWIDTH)
 dim float num
 dim integer k
 cls
 message 3, 1, "Enter your text. Blank line to end."
 multiline 3,3,10
 for k = 1 to 10  'prints final result to console
   print n$(k)
 next k
 multiline 3,15,1,20
 print n$(1)
 message 20,20, "Enter a number..."
 num = getNum(20,22,"42.0")
 print num
option console both
end
 ' creates a box for multiline text input
 ' Gets valid numeric input from user
 ' Parameters:
 ' x, y - top left corner measured in characters
 ' li - number of lines
 ' c - number of characters per line
sub multiline(x as integer, y as integer, li as integer, c as integer)
 local integer k
 if c = 0 then c = 79
 box x*tWth - 2, y*tHt - 2,(c+2)*tWth + 4, li*tHt+4,1,rgb(white)
 for k = 1 to li
   n$(k) = GetStr$(x,k+y-1,"",c)
   if n$(k) = "" then exit for
 next k
 box x*tWth - 2, y*tHt - 2,(c+2)*tWth + 4, li*tHt+4,1,rgb(gray)
end sub
 ' Parameters:
 ' Row, Col - location to echo input
 ' Initial$ - default value
FUNCTION GetNum(Col as integer, Row as integer,initial$)
 Result$ = initial$
 Done = FALSE
 do WHILE INKEY$ <> "": loop 'Clear keyboard buffer
 DO WHILE NOT Done
   text col*tWth,Row*tHt,Result$+CHR$(95)+ "    ",lt,1,1
   do
     Kbd$ = INKEY$
   loop until Kbd$ <> ""
   SELECT CASE Kbd$
     case chr$(27)
       result$ = initial$
       done = true
     CASE "0","1","2","3","4","5","6","7","8", "9"
       Result$ = Result$ + Kbd$
     CASE "."
       IF INSTR(Result$, ".") = 0 THEN
       else
         play tone 440,440,100
       END IF
     CASE CHR$(13),chr$(9)
       Done = TRUE
     CASE CHR$(8)
       IF LEN(Result$) > 0 THEN
         Result$ = LEFT$(Result$, LEN(Result$) - 1)
       END IF
     CASE ELSE
       IF LEN(Kbd$) > 0 THEN
       END IF
   END SELECT
 LOOP
 text col*tWth,Row*tHt,Result$+ "    ",lt,1,1
 GetNum = VAL(Result$)
END FUNCTION
 ' Gets valid text input from user
 ' allows basic editing
 ' Parameters:
 ' Initial$ - default text
 ' mx - maximum number of characters
FUNCTION GetStr$(Col as integer, Row as integer, Initial$, mx as integer)
 local rhs$
 local integer done, tlen
 if mx = 0 then mx = 80
 Result$ = initial$
 Done = FALSE
 DO WHILE NOT Done
   text col*tWth,Row*tHt,Result$+CHR$(95)+rhs$+ " ",lt,1,1
   tlen = len(Result$)+len(rhs$)
   if tlen > mx then exit do
   do
     Kbd$ = INKEY$
   'print asc(Kbd$)
   SELECT CASE Kbd$
     case chr$(27) ' ESC
       result$ = initial$
       rhs$ = space$(len(rhs$))
       done = true
     CASE CHR$(13),chr$(9)  'CR or TAB
       Done = TRUE
     case chr$(130) ' left arrow
       if len(Result$)>0 then
         rhs$= right$(Result$,1)+rhs$
         Result$ = left$(Result$,len(Result$)-1)
       endif
     case chr$(131) ' right arrow
       Result$=Result$+left$(rhs$,1)
       rhs$= mid$(rhs$,2)
     CASE CHR$(8) ' backspace
       END IF
     case chr$(127) ' delete
       rhs$= mid$(rhs$,2)
     CASE ELSE
       if isChar(Kbd$) then Result$ = Result$ + Kbd$
   END SELECT
 LOOP
 text col*tWth,Row*tHt,Result$+rhs$+ " ",lt,1,1
 GetStr$ = Result$+rhs$
END FUNCTION
function isChar(ch$) as integer
 if asc(ch$) >31 and asc(ch$) < 128 then
   isChar = 1
 endif
end function
sub message(Col as integer, Row as integer, txt$)
 ' prints text at given location
 text col*tWth,Row*tHt,txt$,lt,1,1
end sub
Written for an early beta firmware but stills seems to be OK
Herry
Posted: 01:40am 21 Sep 2020
With regards to Lizby's post, the 2 char variable names were from the very start on the TRS80 1978 with 4K (yes that's K) memory! Tassy Jim, I am working on a much shorter routine, which is designed to respond to the monkey text. No need to signal end of input other than pressing enter (clever monkey...). Limit of files signaled by routine. User cannot go past it. I won't post that code until it works 100% because I don't want suggestions unless I'm stuck, and you experts will not be able to resist! With regard to the very kind assistance I have received on here generally (Most from TJ!) I do not bother you blokes until I have hit a brick wall (usually my own stupidity).
My routine still has operational flaws. I would post it now if each and every poster solemnly promised on a stack of 16K DIL RAM chips that they would not make any suggestions until I connect an electrolytic across AC. (I've done it -- an anode of the rectifier rather than the KT66 --replaces the starting pistol)....
Oh, one more point. Because BASIC was (before QuickBasic) an interpreter language not compiled, to speed things up the subroutines were put at the start of program, rather than the end.
Edited 2020-09-21 11:47 by Herry
Herry
Posted: 08:13pm 22 Sep 2020
OK Here it is. This is my conversion of the old BASIC spaghetti code tha I posted earlier . I should explain that this was part of a standard module I used for business programs in the 80s and which lasted until the 90s in a DOS office. The operator was faced with the main area of the screen and could make various entries at the foot. The entries were given fixed limits.
'* TRIES
CLS
'* user defined; converts character to pixel count
FUNCTION WD(Y)
 WD = Y * MM.INFO(FONTWIDTH)
END FUNCTION
'* main program
STRINGENTRY("THIS IS THE TEST PROMPT",6) '* string, max length eg 6
PRINT@(10,150)"BACK NOW WITH ENTERED STRING >> "+ANS$
'* end main program area
'* subroutine area
SUB STRINGENTRY(X$,LIMIT) '* X$ = prompt; ANS$ = Result. GOSUB 800 in old BASIC code
 COLOUR RGB(CYAN) '* for entry routine
 ANS$="" '* start wih empty string
 DO '* build string
   ANSCHR$ = INKEY$ '* pick up char
   IF ANSCHR$ = CHR$(13) THEN EXIT DO '* exit to main program if <ENTER> is pressed
   IF ANSCHR$ <> CHR$(8) AND LEN(ANS$) < LIMIT THEN ANS$ = ANS$ + ANSCHR$ '* build ANS$ until limit
   IF ANSCHR$ = CHR$(8) AND LEN(ANS$) > 0 THEN ANS$ = LEFT$(ANS$,LEN(ANS$)-1) '* backspace
   '* left margin 10, and flash entry point (static for rest)
   IF LEN(ANS$) <> LIMIT THEN
     PAUSE(150)
     PRINT @(10,570)X$+":"+ANS$+CHR$(46) +STRING$(LIMIT - LEN(ANS$)-1,46) +CHR$(222)
     PAUSE(150)
     PRINT @(10,570)X$+":"+ANS$+CHR$(32) +STRING$(LIMIT - LEN(ANS$)-1,46) +CHR$(222)
   ELSE '* unless field is full
     PRINT @(10,570)X$+":"+ANS$+CHR$(222)
   END IF
 LOOP
 COLOUR RGB(WHITE) '* restore normal colour
END SUB
Herry
Posted: 07:15am 23 Sep 2020
No response... Either posters were stunned by my brilliance, or more likely shattered by my incompetence...
